loses power, steering goes stiff and stalls
jess.scobie
- Apprentice Bongonaut
Hi, my automatic bongo friendee 2.5 diesel seems to have a problem. I will be driving along at around 80-90km/h when my revs and gears drop until the van comes to stop, the steering becomes very stiff, the lights on the dash all come on and then the van stalls. I can't start it straight away but after a few minutes it jerkily starts up. This has happened to me on two occasions, both long journeys and will happen a few times in a row before going on like normal. I have a feeling it could be fuel related but don't know much about engines! It has happened both times when the fuel has a quarter left and once I've filled up then its ok. I have just had it serviced so fuel filters have been changed. Any help would be greatly appreciated as we are leaving to morocco in a week and want to have a sound bongo to start the trip! Thanks, jess
- Driver+Passengers
Re: loses power, steering goes stiff and stalls
I wish you all the best for the trip!
Re: fuel filter - it would be worth checking the banjo filter in the top of the fuel pump, too.
search.php?keywords=banjo+filter&submit=Search
Hi jess.scobie,
It might be worthwhile checking the Fuel Stop solenoid,could be a faulty solenoid or a bad connection.
You could also check the fuel cap vent.
PS what age is your vehicle?
Cheers.
Cheers.
yep try it without the cap........as blocked vent could well be it
if it is wash it out
Does sound like it could be a vacuum developing due to a blocked fuel cap.wonkanoby wrote:yep try it without the cap........as blocked vent could well be it
look for some recent posts by author simon jones, he came up with a new slant on this old chesnut
, theres a little thimble type breather clipped up near the tank on the chassis, this vents the tank, check its operating ok.
Steviesee
Jess,
The same thing happened to me on Saturday on the motorway, and it had just been serviced. Turned out that I had a dodgy fuel filter. Maybe there's a bad batch out there?
Where about in Morocco are you heading for? I'm heading down in 2 weeks time for some surf...can't wait!
Stevie
Stevie
- Driver+Passengers
viewtopic.php?f=3&t=52764Northern Bongolow wrote:look for some recent posts by author simon jones, he came up with a new slant on this old chesnut![]()
