Hi all,
We are expecting a baby and went to try our group 0+ car seat in our new bongo today. The car seat is part of a travel system pram so we were really hoping it would fit. It seems to be okay as the buckle is sitting away from the base of the seat; but can anyone confirm this look okay for us?
Its a Cybex Aton that goes with the Mamas and Papas Sola pram travel system.
https://picasaweb.google.com/1021225301 ... 1569355010
Thanks for your help.
Baby Car Seat-dont think mine has buckle crunch....does it??
Moderators: Alison01326, mobilecat
- Bongonaut
- rhino-wayne
Re: Baby Car Seat-dont think mine has buckle crunch....does
TBH it looks as if you do not have the belt/seat installed correctly. The belt should be fully into the..belt holder/groove thingy..and not folded or twisted.
Which Bongo seat are you using for the child seat? 3 point seat belt or lap belt?
regards
Wayne
p.s. I sell car seats & pushchairs
regards
Wayne
- rhino-wayne
http://www.mamasandpapas.com/product-vi ... 4401&vid=0
I shortened the lap belt (buckle end) by reversing the bracket under the seat & looping belt once around under seat bar
- Bongonaut
Thanks for your replies. ts the three point belt on the middle row of seats that we're using. It was the assistant in Mamas and Papas that fitted it; I agree it could have been fitted better. I think though that if I pulled the belt back so it was in the groove thingy the buckle still wouldnt be touching the seat, so if thats the case this would be okay?
- rhino-wayne
Hi, yes the belt should be fully into the grove. check the manual/side of seat instructions, most show point of "buckle crunch" & how to install correctly.
- rhino-wayne
If the belt requires shortening you can use method as mentioned in a post above or get the belt shortened with
http://www.stopbucklecrunch.co.uk/
- Bongonaut
Thanks, I'll look into this. And thanks to everyone for their replies.rhino-wayne wrote:If the belt requires shortening you can use method as mentioned in a post above or get the belt shortened with
