Diesel smell after aircon
After aircon has been on for a bit and we park up there is a smell of diesel. A friend said we should run the aircon more often and for longer to clear it - is that the reason or should we check something else?
Re: Diesel smell after aircon
Aircon should be used weekly to stop the seals drying out and the gas leaking. It will also stop the pongs you get with a rarely used aircon, but I've never heard of it smelling of diesel
Have a wee look around and under the injector pump when the engine is running for a start,if you smell (unburnt)diesel you have a leak.
Thanks guys - after running the aircon more regularly it went.
