I've just replaced the strange array of electronic equiptment and Japanese audio bits that frequented my dash.
The new stereo works well with the exception of a radio signal.
The aerial antennae is plugged in but does not seem to be giving any kind of signal...
Does anyone have experience to share that might help resolve the issue?
Radio Bongo...
Re: Radio Bongo...
Check back along the aerial cable there is another plug and socket just under the the dashboard area where the cable rises up the side of the window screen;
See here http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Re: Radio Bongo...
Hi Geoff,
Checked this back - seems to be joined - The cable itself is covered in foam so it's quite hard to see, feels well joined when I push the ends together.
Is there a way to test that there is a join through to the aerial?
- mikeWalsall
Re: Radio Bongo...
You could test for continuity with a multi meter..
Re: Radio Bongo...
It might be worth checking that the radio itself is actually working, push a wire into the aerial socket at the rear about 30" long do you receive any signals ?
If that works OK, then its probably worth checking with a meter for two things;
1. That there is continuity between the end of the plug and the external aerial.
2. There is NO continuity between the end of the plug and earth/chassis of the vehicle.
Re: Radio Bongo...
Thanks all, I'll get the meter on the job tmrw
Re: Radio Bongo...
Found the fault, the aerial lead was disconnected at the joint shown on the wiring diagram. I'd not traced the lead far enough along before. Thanks for the info.
Re: Radio Bongo...
Its been reported a couple of times before so its a reasonable bet that would be the cause
