I brought my bongo nearly a month a go specifically for a 3 month tour of Europe my girlfriend and i plan to do next year. The idea is to make the bongo mechanically sound in the next 6 months, improve the existing rear conversion with better bed, fridge and more storage space and then tell my boss what to do with his job (politely of course)
So far i have used the members fact sheets to do the oil and filter change, fuel and air filter, coolant drain flush and refill. I also had to change the glow plugs as 1 hour after purchasing my bongo it would not start so after trawling the forum and bongo clinic for an evening i deduced that it must be the glow plugs, sure enough 1 plug had completely failed and 2 more were very slow to heat up so i changed all 4. When changing the plugs i noticed that there was a small leak on the first diesel injector (working left to right) this does not cause a problem to the running of the engine it runs very well but i want to get it sorted.there appears to be not much mentioned on the forum with regard to injectors so i was hoping the more experianced of you bongoers would be able to advise me on what to do.
all advise/ experiances welcome.
thanks
adam
