The rear air con/heater doesn't work.
Hello
I have a lovely 99 V6
The lights are on at the front as well but no air blowing with fan or air con.
I checked the fuses all good, swap them around (30A) nothing changed.
Can anyone help me with what can be wrong?
thanks
RIcardo
thanks
RIcardo
Re: The rear air con/heater doesn't work.
i think im right in saying the back only works if the front fan is on, have you done this.
got the old manual one myself, but presume the digital is similar in operation.
The Air Con can only be turned on from the front, but the Fans should be controllable from the rear, once turned on from the front.  I seem to recall a couple of people having to replace relays in the past.  Worth a search on the forum, if no one shouts in the next few hours.
Hello.
everything is on at the front.. it use to work fine.
Now the lights are on but no air con or normal fan works at the back.
At the front everything works fine.
I'm going to lok for Relay posts.. I'm not really sure what I'm looking for.
Thanks for helping
Thanks for helping
I can see that is at the back.
Do you know how can i get to it.
How does it look like.
probably a silly question, Sorry about that
Its just behind the drivers seat on the offside;
see this thread for photo's of unit http://www.igmaynard.co.uk/bongo/forum/ ... 62#p570162
the relay (black, rectangular with writing on it) is just right of centre, on a bracket screwed to the case with a white plug and black cable loom leading off to the right. If you have the electronic version of the controls there will be two relays; G3-20 (Fans on/off) and an additional one G3-18 which is used to turn the fan on for Max blow.
The thread also includes a description of how to get to the unit. Normally easier if you haven't got a conversion !
I have a digital one.
I can see it on the picture.
Can I get to it by removing the Air-con control unit or I need to remove all the plastics from that side of the van?
I have a rear conversion, everything original on that part of the van
I hope is easy to get into it.
I never removed anything from it.
Thank you so much for helping
You can remove the side panel in under 5 minutes. Undo the screw in the grey trim by the controls and remove. Undo 2 screws holding controls to metal frame, remove unit and undo connector. Slide drivers seat forward and tip the seat back towards front of van. Gently pull the trim away starting at the top in the middle. It will pull off but watch out for the metal clips that tend to ping off. Once it's about 6 inches away from the body, look down the top and you will see the cable that goes to the green light and this is taped to a plastic clip. Slice thru tape with a knife and remove bulb from holder by turning it 90 degrees. You'll need to do some jiggling to get the panel out, but it's pretty straight forward.
Refitting is the same in reverse, but remember to check the seat belt is not caught up behind panel.
thank you so much. I'll try that tomorrow.
I'm trying to buy the relays but I can't find any place selling the parts .
Does anyone know where to get it from.
I'm looking at the parts link sent above but I can't identify it.
can someone help me finding the part number for relay G3-20 & G3-18
Woah, hold on with the ordering new bits.!!??
Don't you hold one of the fan buttons down on the front heater control a little longer to get the rear fan to go???
I don't know mines manual, but on the whole a similar principle.
the lower right button is the one turns rear fan on and off
You can check it at first by simply swapping the two relays around, if you then get the fans working at all but Max speed it points to the G3-20 relay being faulty, but its worth popping the case off and having a look it might just need the contacts being cleaned!
Hello.
I did it all, very easy to get to.
I toke some pictures but not sure on how to upload them.
I swapped the relays and nothing, the motor doesn't start.
the contacts look really clean no rust, looks new.
I'm attaching some pictures please advise.
hoping that is not the engine
relays -- H300
H260
relays -- H300
H260
