heat light (V6)
heat light (V6)
The heat light on my V6 came on and has stayed on after a problem with oil leaking from the rocker cover onto the plugs and the engine overheating. The rocker cover gaskets have been replaced and the engine is running fine. The light is still on, I have tried resetting the fault codes as described in the bongo fury fact sheets but no luck. Has anybody come across this problem or does anyone have any ideas.
Alan350
Alan350
Re: heat light (V6)
Once the sensor is dead its dead, do a search on it i have posted plenty on it, it tells you that your cat pipe has overheated for some reason possibly due to missfire, raw fuel entering the pipe, upto you if you want to replace or not
if you disconnect the sensor at the plug and cable tie it out of the way the dash light will behave normally
the heat sensor is not ecu controlled but could also be tripped due to long term lambda probs and overfuelling, I just disconnected mine and left it, it doesn't controll fuelling
not worth the £120 odd squids
Dar
Dar
Re: heat light (V6)
What a result, I disconnected the sensor, which was quite easy to reach, and the heat light is now off.
many thanks for your help.
Alan350
Alan350
- Tribal Elder
Re: heat light (V6)
After doing this would it have an effect when it comes to MOT/emmisionscheffy34 wrote:Once the sensor is dead its dead, do a search on it i have posted plenty on it, it tells you that your cat pipe has overheated for some reason possibly due to missfire, raw fuel entering the pipe, upto you if you want to replace or notif you disconnect the sensor at the plug and cable tie it out of the way the dash light will behave normally
Dar
Izzy
Re: heat light (V6)
wishmaster wrote:After doing this would it have an effect when it comes to MOT/emmisionscheffy34 wrote:Once the sensor is dead its dead, do a search on it i have posted plenty on it, it tells you that your cat pipe has overheated for some reason possibly due to missfire, raw fuel entering the pipe, upto you if you want to replace or notif you disconnect the sensor at the plug and cable tie it out of the way the dash light will behave normally
Dar![]()
Izzy
Hasn't on mine for the last 3 years
Re: heat light (V6)
Hi guys, sorry to bump up an old topic but I had the same problem with an oil leak and now my Heat light is stuck on. The MOT is due soon so I would like to disconnect the sensor that is responsible for the indicator light however when I look underneath, I see two possible culprits. One closer to the engine with a visible plug and another forther down the vehicle.
Any ideas which is the one to disconnect?
I dont want to accidently disconnect the Lambda sensor rather than the heat sensor.
Thanks chaps.
Thanks chaps.
Aqua V6 AFT with side conversion
Re: heat light (V6)
I took this picture to help with clarifying which wire......
Is it cable A or the pretty new looking cable B that I unplug to get rid of the "Heat" light off the dash?
Thanks,
Thanks,
Re: heat light (V6)
A is your lambda sensor, therefore B must be the one you should try unplugging. Note: the bulb may light up when the circuit is high resistance so disconnecting it may not work. Interestingly, I don't have one of those on my 2002 V6.
Now, I'll probably get shouted at
, but if I were you, I'd remove the bulb if you cant readily fix it. It's not a safety feature like ABS or airbags, so won't be a light that is specifically being looked for during an MOT. When I had my instrument panel out the other week, I found there was no bulb holder in the heat light socket. On closer inspection, there is no sign it was ever fitted with one as the PCB tracks were totally unmarked: there would have been a track scored into them if a bulb holder had ever been inserted. I even stuck a bulb in there and it did not light up when the ignition is switched on. My conclusion is that is the lack of the bulb, no wiring under the floor and no sensor on the exhaust (which is genuine Mazda) means this was not fitted to the later models.
If anyone has more info on what this sensor does, I'd be interested to find out.
- mikeWalsall
Re: heat light (V6)
Just looked at a recent pic; of the rear of my Speedo panel .. and I have to admit comparing the printed circuit board bulb locations, it looks like my 1998 never had a cat. over heating bulb in.. where as it is obvious that the ABS once had a bulb / holder in ..
Re: heat light (V6)
Hi Simon, thanks for directing me to the correct lead. I will try disconnecting it later and see what happens.
