Battery monitors
Moderator: Doone
Battery monitors
So since the TV has been fitted I've done both batteries twice now, either leaving stuff on accidentally or by using it too much and running the starter batt down as well.
Any recommendations on what gauges/monitor I could use in the back?
I have a blue LED one that lights up but it might be a bit annoying constantly on.
I could do a switch, but I thought I'd ask around on here first as to what you have fitted?
ta
ta
Re: Battery monitors
Not what you've asked for, but I would fully recommend getting round your problem with a solar panel!
Yep thats next on the list - come on Santa
- mikeWalsall
Have you got a split charging system .. ??
Maybe get your lecky system properly sorted / working right ..
The leisure battery should be for the 'consumer' side ..
The starter battery should be just for starting .. and independent .. of any lecky guzzling 'gadgets' ..
I fitted a volt meter with a switch in the back of my BMW clock
I did wonder about moving it to my proto type roof console
This is what I used but from a different supplier
http://www.ebay.co.uk/itm/1pcs-Blue-LCD ... 3ce9f51291
Heres a few cheap ones
http://www.ebay.co.uk/itm/12V-24V-Car-D ... 51c3d76ca7
http://www.ebay.co.uk/itm/12V-24V-Motor ... 3a99e1bb13
http://www.ebay.co.uk/itm/RED-Mini-Digi ... 3396b7a1a5
Thats what I thought but it may be that the starter was down anyway - bit inconclusive...
I have a Cyrix-CT installed maybe I've wired it wrong as it has a start assist function, and its feeding the wrong way somehow.
Or maybe I'd flattened it some other way
Winchman, that blue one is what I have - I need to be able to turn it on and off to check so switch is possible solution.
Somewhere near the TV in the rear conversion would be my thinking...
That way I won't get carried away, and need a jump start!
Solar is the future though for sure.
Switch was only cheap from Ebay
If you use one of these you cant accidentally leave it on.
http://www.ebay.co.uk/itm/12V-Momentary ... 3cce72b35d
roosmith wrote:Not what you've asked for, but I would fully recommend getting round your problem with a solar panel!
Seconded
Been said but
Get your electrics sorted
You should not be able to flatten your starter battery
You will know when your leisure battery is getting flat when watching TV I loose the sound from tv
I bought a twin gauge following a recommendation from someone on the forum. Can't locate the eBay link currently but it came from South Africa for around £13.
Hi Simon that was my reccomendation here's the ebay link:
http://www.ebay.com/itm/12V-LED-double- ... TQ:US:1123.
And forum topic here:
http://igmaynard.co.uk/bongo/forum/view ... 64#p620264
Thanks dobby, I couldn't find your link anywhere
. Cheers for the recommendation. I've not fitted it yet, but it's on the 'to do' list.
No problem, fitted mine a while ago, works well I fed the wires through the unused air sensor slots to the right of the glove box.
Gone with this one
http://www.ebay.co.uk/itm/400749236254
And bought the push button for the LED one I had already - we'll see which is better.
Think I sussed out the battery issues, the original converter had run power to the rear direct to starter battery, and I'd used that instead of the power I ran looped off the leisure battery.
Then promptly killed both by watching TV
