External screen cover.
Moderator: Muzorewa
Rapidair65
Post by Rapidair65 » Fri May 22, 2015 8:23 am
We bought an external screen cover from Just Kampers. It fits over the door corners and covers the windscreen and door windows. After a recent wet trip to Derbyshire, the screen section was soaked through including the insulation wadding. It's taken a week to dry it out. Should these screens be waterproof and has anyone else had this problem? We bought the cover as it was easy to fit but it now looks like a set of internal covers would have been better.
1998 green and silver V6 called 'Blossom'
2004 white 2 litre tin top called Buzz.
Re: External screen cover.
Post by mikeonb4c » Fri May 22, 2015 8:27 am
Rapidair65 wrote:We bought an external screen cover from Just Kampers. It fits over the door corners and covers the windscreen and door windows. After a recent wet trip to Derbyshire, the screen section was soaked through including the insulation wadding. It's taken a week to dry it out. Should these screens be waterproof and has anyone else had this problem? We bought the cover as it was easy to fit but it now looks like a set of internal covers would have been better.
I've got one of those and don't recall having problems. I'd contact them to see what they say.
dave_aber
Post by dave_aber » Fri May 22, 2015 8:35 am
I've got one too, and it's been waterproof through many a soaking.
Sounds like you have a defective one - leaking at a corner or similar, and once the water's in the waterproof outer layer is preventing it drying out.
Image...Image
Rapidair65
Post by Rapidair65 » Fri May 22, 2015 8:46 am
Sounds about right. I have just emailed Just Kampers for their comments.
Rapidair65
Post by Rapidair65 » Fri May 22, 2015 9:39 pm
It appears that the covers are only showerproof. Just Kampers have offered a refund.
Simon Jones
Post by Simon Jones » Fri May 22, 2015 11:21 pm
I must admit I've never been a fan of external screens as they would have to be put away when wet or damp. Not a problem with a bigger motorhome where there's plenty of storage options for soggy things to be stashed.
Post by mikeonb4c » Sat May 23, 2015 9:51 am
Simon Jones wrote:I must admit I've never been a fan of external screens as they would have to be put away when wet or damp. Not a problem with a bigger motorhome where there's plenty of storage options for soggy things to be stashed.
I have both but always end up using the external as its less fuss to put in place and does a better job. The wet issue is the same as a side awning: if you have to pack it damp (in its bag so it's ok in da car) then you have to dry and air it at home. Or you can try and avoid wet weekend camping, which I have to confess I try and do :oops: :lol: 8)
Rapidair65
Post by Rapidair65 » Tue May 26, 2015 8:19 am
I'm going to try treating the cover with Grangers 'Fabsil' to try and waterproof it. We are in Yorkshire this weekend at Knaresborough so I can test the effectiveness in our wonderful summer weather!
helen&tony
Post by helen&tony » Tue May 26, 2015 8:32 am
Might I offer a bit of advice?....DON'T use anything with silicon in it, that might get washed onto the paintwork....that also includes fancy car polishes, as if you ever need paintwork done on the car, it's a flipping demon of a job getting rid of silicon deposits, and thus getting paint to stick without blobbing.....gggggrrrr.
Best bet is to treat the external cover as a "lesson learned"....I think it'll put me off buying one!
Good Luck!....and have a nice trip :D
Rapidair65
Post by Rapidair65 » Tue Jun 02, 2015 5:50 pm
The Fabsil worked! I now have a waterproof windscreen cover! AFT cover next. :D
Post by mikeonb4c » Wed Jun 03, 2015 8:41 am
Rapidair65 wrote:The Fabsil worked! I now have a waterproof windscreen cover! AFT cover next. :D
Excellent. May you enjoy many rainy camping trips :lol:
