Front crossmember
nth
Re: Front crossmember
Post by nth » Mon May 23, 2016 8:25 am
Tessie wrote: the only problem I had was that one of the underneath bolt holes on the side plates didn't match up. However, this could have been my fault as I did a bit of banging and crowbarring before reading how others had done the job so I could have bent it out of shape. A little elongating of the hole soon solved the problem.
Had that exact same problem too, but yes there was a bit prying & levering getting done. just elongated the holes to persuade it to fit back on. had to make the same notches too.
I reckon if doing it again I could knock off 2 hours.
95 2.5d 4WD AFT
Tessie
Post by Tessie » Mon May 23, 2016 8:00 pm
nth wrote: Had that exact same problem too, but yes there was a bit prying & levering getting done. just elongated the holes to persuade it to fit back on. had to make the same notches too.
Hopefully you won't have to do it again, not on yours anyway :wink: , Maybe you are offering to do the job for other Bongo owners :roll: :lol:
Never run out of road, traction and ideas at the same time.
Post by Northern Bongolow » Mon May 23, 2016 8:04 pm
someone i know is doin one tomorrow, [-o< [-o< :)
Tessie
Post by Tessie » Tue May 24, 2016 1:11 pm
Good luck to someone you know and the 'million' spot welds you, sorry, they will be drilling out :lol:
