We started for a change with a Bongo with a "Good Coolant System" instead of trying to fix an overheating Bongo, we tried to remove heat from an untouched for 3 years plus Bongo with no oil or water leaks, original head and water pump etc,
Bongo A
1st Attempt
Mason alarm fitted
Good readings generally.
Actions:
New Blue Print Stat
New Intermotor Temperature Sensor Switch
New Blue Coolant
Speed Flush
New Gear Box Oil used millarmatic DM
Results Observed:
Slight but definate raised temperature according to gauge (suspect sender inaccurate) by could be copy stat. Ran for two weeks, but not happy as would have expected lower general readings.
Spoke to you reference Stat Operation with regard to disc at the top of the stat shutting off hot head water return.
2nd Attempt
Drop Coolant, not reused
Fitted New Mazda Temp Sender
Fitted New Mazda Fan Switch
Fitted New Mazda Stat
New Red Coolant fitted (Carplan)
CHECK STAT TOP HOUSING CLEAN – It was gasket face clean
Results Observed:
Tremendous difference, the control temperature is achieved and maintained easily (Stat control) at a lower temperature band well away from the fan level temp, and away from the danger level.
The auto box warms better and quicker therefore performs better with less heat generated which would need to be cooled by the rad.
Engine and Gearbox now working at correct temperature levels giving smoother results.
Conclusion:
The stat is key. To us the £7.00 copy or £15.00 Mazda, it has to be genuine.
Thermostat housing needs to be very clean to seal correctly
Mason or one of Haydns gauge modifying instructions would show up this in relation to narrow working or operating temperature band and if these temps stray either up or down then the stat/housing should be checked .
Bongo B
History:
New Ranger Cylinder Head fitted 2 Years ago
New Mazda Radiator, 2 Years
New Water Pump, Unknown Brand, 2 Years Ago
New Copy Stat, 2 Years ago
New Coolant, 2 Years ago
Garage Bill = £1800
Full Silicon Hose set fitted, 18 months ago
12 months satisfactory running.
Then bought a light weight Caravan, raised temps noted via Mason Alarm to excessive levels. In the last three months over the winter period symptoms getting steadily worse to the point where anything over ½ hour high speed motorway driving temperature would steadily increase and would not decrease until fan level is reached. It would maintain levels, not cool levels. Fans where then wired manually and water wetter was used to pull down excessive temperatures.
Transfer of Knowlege from Bongo A to Bongo B
New Mazda Stat fitted
Bongos A's Original Old Mazda Temperature Sender Fitted, cleaned up.
Bongo A's Original Old Mazda Fan Switch fitted
Stat housing Top Disc Port from Head found to be dirty and deposit build up particularly at the flow from heaters across the stat edge: See Pics
Removed and Cleaned as per pics.
New Mazda Housing/Engine Gasket fitted
Red Coolant (Carplan)
Result:
Result!!!!!!!
as per Bongo A
Final Point:
One final point of note is that in "my opinion" a used lazy stat, when pan tested to boiling point only gives a low or inaccurate reading the 1st time tested. On second test it will normally be "Re-awakened" to work apparently normally and test well against a new stat. "Very confusing"!!!!!!!
Do they become Bongo Bound??????
