There are quite a few dubious quality ones venturing across from the Peoples Republic............ of Chinamikeonb4c wrote:Can't see Tesco Value or Poundshop in the list. Can't be long before they join in thoughmikexgough wrote:90496116 .......... yer pays yer money....
Bilstein Febi ones......... for Vectra........£11.87 inc VAT
Some other Cross References if your going the Vectra route.........
Boge BAL3007
Delphi TC686
FAI Automotive SS505
First Line FDL6367
Moog Chassis Parts OP-LS-5582
Moog Chassis Parts OP-LS-1904
Motaquip VDL710
Opel 350610
Quinton Hazell QLS3200S
Saab 4686606
Vauxhall 90496116
Drop links
- mikexgough
Re: Drop links
Re: Drop links
Vauxhall Vectra link, pt no. 90496116 at full stretch:-
Listen to the beat of the Bongos!! Black V6 tin top
Re: Drop links
The cheaper ones I got from Ian last year (which were the same as the ones I originally got from ebay & failed within the year) started knocking within 8 months, rubber was intact at that point, by the time I got around to replacing them @3 months later with blueprint ones supplied by Ian, the rubber had gone on one & was perishing on t'other (they were passed back to Ian to chase up supplier).
Blueprint ones only been on a couple of months, but as said before, high hopes though as build quality comparable to the Mazda supplied ones.
BongoBaz fitted the cheap clear booted ones I got on fleabay from a different supplier (for @£10 the pair I think) at around the same tie & still going strong apparantly when I asked him at Softies. It's a bit of a lottery
