Overheating. What's gone wrong with my bleeding technique?
antique
over heating
hi sorry probally both, head cracks on exhaust side.
patmckenna
Hi Guys
I thought it was time to give you an update. Thanks for all the replies, I've been reading through them carefully and I've also been following the record-breaking(?) thread about the correlation between radiator and thermostat.
During the last few days, I retackled my bleeding problems. I carefully and systematically followed all procedures, making sure that at all times I avoided re-introducing air into the system through the expansion tank. I had the opportunity of squeezing various hoses to aid the process - including the big hose coming from the radiator to the head. located under the driver's seat.
When I felt (after some hours) that I had as much air out of the system as I could, I took the beast out for a few circular tours of the neighbourhood, including some satisfyingly steep hills. After each circuit, I stopped the van, and vented any air from the system via the bleedhose. Each time I vented, there was air present. I topped up the expansion tank if necessary. On the third circuit, the temp gauge shot beyond the 11 o'clock position, I pulled in, vented my spleen and the large volume of steam from the bleedpipe. I didn't get any gurgling and spitting from the expansion tank but I imagine this was because I had stopped immediately and and released the pressure elsewhere.
I am now convinced that I do indeed have a problem with the head or the head gasket...
On Friday morning I went to the local garage(s) to have the system pressure tested, but everyone had gone away for the Easter Weekend. I'm off to Germany for a few days on Monday, so things will have to wait.
I think I need to do the following:
Have a pressure test to see if they can pinpoint where I am either losing fluid and/or pulling in air.
Perhaps a dye-test at the same time?
Look seriously at having the rad off and tested for blockages.
Well, ther we are. No further but a little wiser. Will keep you all informed. Thanks for the help.
Pat
Pat
antique
