my bongo-should i keep it or sell?
That's interesting that it doesn't seem to make any difference when you swap two leads over,it implies that your engine is running on four cylinders at the most....Did i read somewhere that you have an oil leak that is contaminating the plugs also?
- dandywarhol
Fuciffanno....................lizard wrote:francophile1947 wrote:If you're doing the rocker cover gaskets, you can check the cams for wear at the same time. Contact Mazda dealer for prices of cams and tappets and take it from there.
It might also be worth trying the ATF trick for silencing the tappets.
As your car has been stood for so long, I'd give it a little while before giving up - it's amazing what a good run can do for a "sticky" engine.
The ATF trick wouldn't be an Italian tune up, by any chance.
- hogggman
hi,
yes,there is oil contamination on 3 plugs,but not sure if/how many are/are not running.i don`t see any numbers on the leads,but the guy who imported it has put l-m- r (left-middle-right,i assume)on the plug leads.forgive me,but i only straed looking the bongo over this last weekend,and as yet i don`t know where the distributor or coils are.
thankyou
jamie
thankyou
jamie
If the "other" end of the leads i.e. opposite ends of the plugs go to a black box,then that is the coil pack, these can fail, but chances are they will be expensive, it'd be good if a local v6 owner could temporarily swap this item with yours (after new plugs are fitted) to isolate the problem.
At least it will narrow down the amount of new parts you start chucking at the bongo,its throwing good money after bad with that kind of guesswork.
Have you tried a locally respected mobile tuner? Bongo knowledge or not, a decent tune up bloke could pinpoint the problem in no time at all,the priciples are the same no matter what vehicle the engine is fitted to...
- The Great Pretender
It maybe worth investing in some spark plug testers, saw some ones in halfords the other day, 4 for under £5. That is a quick and cheap way to see if the spark is arriving at each plug.
Personally I'd do that first, then leave compression testing etc to a good local mechanic, and hour or so of his time would put you in a better position to know what could be wrong.
BTW how does it drive, if it's only firiing on 4 or 5 then surely it would be pretty slow and underpowered?
Keep us posted and don't give up.
Andy
Andy
dp bradford
Favourite trick with the Rover V8 was to drain around a litre of oil out and then run the engine whilst rapidly pouring the oil back in. Cured sticking tappets for mefrancophile1947 wrote: Hi hogggman
I used to be a Mazda Technician and when it came to rattly tappets Mazda technical advised an oil change and when refilling the oil you should add 1 ltr of ATF and believe it or not it does work I have done it several times including on an old Audi 80 sport I had and yes it worked on that as well.
Dave
