waeco ms50 not working
robdrinky
Re: waeco ms50 not working
Post by robdrinky » Wed Jul 16, 2008 9:57 pm
as i am sure you remember-test A involves operating the reset button and the on/off button but not the set button so there is room for doubt about that connection but they all have continuity.
without information about what voltage to expect at each connector there is nothing else i can check.
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Post by Simon Jones » Thu Jul 17, 2008 8:28 am
Which connections in particular do you want voltages from? I can have a measure this evening, although I probably wont be able to measure them with the cc engaged.
Assuming the 4 wires to the switch are ok - it lights up so means the green & one other (possibly brown) is fine.
The speedo pulse is ok - you've got the flashing led on the controller
Have you checked the connection to the brake light switch, or the unused clutch switch? If either of those are earthed, it would disengage it.
scanner
Post by scanner » Thu Jul 17, 2008 9:23 am
Simon Jones wrote:Which connections in particular do you want voltages from? I can have a measure this evening, although I probably wont be able to measure them with the cc engaged.
Yes try disconnecting the brake wire just in case that is shorting out the system and preventing it engaging.
robdrinky
Post by robdrinky » Thu Jul 17, 2008 10:57 am
i was thinking of checking output voltage to the actuator from the black box and from the set/on off/resume to the box.
i would of thought test A would fail if there was a problem with the brake light or clutch switch-but cant hurt to make sure.
any figures much appreciated.
robdrinky
Post by robdrinky » Thu Jul 17, 2008 4:38 pm
well you could have knocked me down with a feather-a guy from dometic finally called me back this afternoon. =D>
had a discussion and he will send a replacement unit to me-fingers crossed it arrives (and works)in time for our up coming trip into france 8)
Post by Bob » Thu Jul 17, 2008 9:14 pm
Good luck [-o<
Big Rich
Post by Big Rich » Fri Jul 18, 2008 12:28 am
Hi just to say fitted I fitted the MS50 over a month ago, and was 100% correct on instalation, i also had a dead un ! out of the box, bought off ebay from Germany, used Simons very detailed instructions and re checked every connection...still dead, contacted weco UK ... they said send it back, now one month later and i am still chasing it, usual crap excuses, got to ring back monday to see if they can find it .... LET ALONE FIX IT !! and the technical line is a premium rate number to boot!!!!!!! anyway i'll keep you posted on the progress ......thanks Big Rich
Post by missfixit70 » Fri Jul 18, 2008 12:55 am
These reports of duff ones & the aggro involved is seriously putting me off getting one :?
scanner
Post by scanner » Fri Jul 18, 2008 1:28 am
missfixit70 wrote:These reports of duff ones & the aggro involved is seriously putting me off getting one :?
Lots of us have one that work perfectly 2 or 3 have had problems.
About the same ration as good to bad Bongos and it didn't put you off having one of those.
It may be that as they are getting very hard to find, old stock that has been hanging around for years is getting sold and maybe even faulty ones that are supposed to have been fixed - who knows.
I think that if you leave it much longer you won't be able to get one.at all.
I've just used mine nearly all the way from home to Oxford - not a hitch.
robdrinky
Post by robdrinky » Fri Jul 18, 2008 9:22 pm
the numbers on the website are for an closed office :evil:
contact numbers i have are 01258 414623 or 414633,these guys phoned me on friday.
Post by Simon Jones » Sat Jul 19, 2008 12:03 am
Got some voltage readings, measured from connector to earth, but don't think they're going to help, cos there were taken while stationary:
Actuator: red,white & black - 0v
Switch:
STATE>>> Off / On / Set pressed / Res pressed
Orange (switch common): 0v / 3.13v / 0v / 0v
Yellow (set/resume): 0v / 0v / 13.8v / 4.5v
Brown (on/off): 0v / 0v / 0v / 4.5v
Green (LED): 13.8v / 0.9v / 0.9v / 0.9v
Hope you get a response back from them soon
robdrinky
Post by robdrinky » Sat Jul 19, 2008 8:49 am
thanks for doing that,simon.
at least i can check the panel is doing something.
robdrinky
Post by robdrinky » Mon Aug 18, 2008 8:55 am
update-did not get chance to check the voltages before we set of on our trip in the bongo to france.
on day 2 driving south from reims i said to herself-it would be really nice to press the set button and let the cc do its job and to my surprise the thing engaged and has worked fine since.
electronics are wonderfull :evil:
Matt&JoyBongling
Post by Matt&JoyBongling » Mon Aug 18, 2008 9:16 am
Don't let these few reports put you off - ours has been such a benefit to us which made our problem very frustrating but it has worked fantatically since I soldered all of the scotchlock connections and crimped the 3 bullet connectors that had worked loose.
robdrinky wrote:update-did not get chance to check the voltages before we set of on our trip in the bongo to france.
Hope that it is still working for you :)
Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
Post by Bob » Mon Aug 18, 2008 3:59 pm
Bit like Bongo cooling/head probs, you read about the hiccups, not the thousands that work well. A great mod in my opinion.
Mine didn't work first off 'cos the Scotchlok hadn't made contact on the blue/white speedo cable, soldered - sorted. :D
