Unfortunatly Mike is spot on Anna, the Bongo is a great vehicle for mechanical minded peeps. Take it to your local garage and you get a sharp intake of breath...........not so old wrote:Hi mike,
that sure gave me a lot to think about. Its a matter of weighing it all up really. We are not mechanically minded at all. Every part of the car, except for the obvious is called "A thingy"
therefore as you said, the bongo is more for someone with a knowledge of cars and their workings, but it is a shame for those of us who also like the bongo, but do not possess the necessary skills to do the constant repairs required and therefore bear hefty labour bills.
It is booked in to have the motor and resistor area checked tomorrow and dependant on the outcome, we will have to decide the next move. Thankyou for all your help and advice. I am very grateful to you guys. I will miss you all as well as the car, if it has to go.
cheers Anna
mikeonb4c wrote:Very interesting Anna (and I agree with Simon).
Analysing what you've had to spend:-
* Some were improvements so put those to one side.
* Some were servicing, so put those to one side.
* Drop links etc. commonly need replacing on Bongos (and many other cars) so normal wear and tear
* Wiper motor etc. - a bit of wear and tear / bad luck that struck your car but similar probs are striking cars everywhere (especially older ones)
* Heater motor resistor / fan - well known Bongo problem with good advice on how to fix.
My thoughts are:
* Bongos (and other cars) are MUCH cheaper to run if you can do a bit of your own servicing and repairs. Without that you are at the mercy of garage charges. Unlike a lot of modern cars, Bongos are relatively user serviceable esp. in many areas where they are known to need attention
* Bongos (esp. lifting roof ones) have some complex engineering in them. If one of this items goes wrong, anxiety levels rise quickly at £ outlay prospect. On the other hand, the Bongo is unique in its usefulness, functionality, driving experience etc. - I remind myself of this any time I have an urge to 'chicken out' of Bongo ownership
* All car ownership these days is scary, in fiscal terms. Bongos seem to be depreciating less than many cars, and cost to purchase one is very low indeed for what you are getting. It has to be expected that some of that advantage may have to be given up in maintenance and repair
* If you sell, you will probably take a financial hit esp. in the current climate.
* Bottom line is, can you afford to run the Bongo, both in fuel and maintenance terms. Is the worry of it destroying the dream
* I find it helps to think of my Bongo as a pet. I'm devoted to it so that whilst the potential for big bills is an everpresent worry, it means so much to me compared to just an ordinary car that I accept the possibility and resign myself to it. Having said that, I do have a reserve fund (from my initial budget) with which to tackle a major problem should it arise.
I hope the above may help you decide which way to go. Tough one, but for what it's worth, I think you may (almost) be over the worst. One thing to ask - whats this about rust? This will both have a bearing on long term ownership and on sales price.
Good luck whatever
I love my Bongo and the peeps that have them but alas it may not be (and it pains me to say this) the vehicle for you.
