Doesn't make sense - crankshaft bush wouldn't cause your noise IMOal.b wrote:hi guys
Thanks for all the replies, it looks like the crankshaft bush. Q Is it easy to replace? Is it accessable from the front to fit the bush? Can anybody suggest a supplier. Is it a big job to those that have replaced one before. Any help would be appreciated. I suppose I could emigrate???
Al
oh dear, loud rattle noise
- dandywarhol
Re: oh dear, loud rattle noise
But what is a 'crankshaft bush', except something that sounds a bit like the kind of headline The Sun might come up with (or a dodgy DVD title)
I think you mean bearing,if so it could be Crankshaft trouble.
Hope i am wrong because that is painful on the Wallet.
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
al.b
Hi Everyone
Thanks for all the help. My Brother in law has examined my van last night. After removing the cover underneath the engine he noticed metal filings in the cover. He removed the drive belts and could then see the crankshaft pulley had spun on the engine casing. This explains the grinding noise and if not under engine load would not be as loud. The smell was caused by the belt attached to the pulley rubbing also on the engine casing.
So it looks like the crankcase pulley rubber bush has indeed collapsed and need replacing. It has been suggested that it can be bought on line! but I was wondering if anybody had experienced at replacing one?
Al
Al
Get in touch with anyone breaking one - may be worth pming Harry on here, if not try the usual suspects - Bellhill, bongobits, etc.
- dandywarhol
There's a bush in the rear of the crankshaft which supports a manual gearbox input shaft - thats why i said it wouldn't be causing the problem with an autobox.mikeonb4c wrote:But what is a 'crankshaft bush', except something that sounds a bit like the kind of headline The Sun might come up with (or a dodgy DVD title)![]()
Hi Dandy,is the crankshaft pulley rubber joint not called a (Larry Adler) Harmonic Damper.dandywarhol wrote:There's a bush in the rear of the crankshaft which supports a manual gearbox input shaft - thats why i said it wouldn't be causing the problem with an autobox.mikeonb4c wrote:But what is a 'crankshaft bush', except something that sounds a bit like the kind of headline The Sun might come up with (or a dodgy DVD title)![]()
Cheers Malc..
- dandywarhol
Yep, thats what I know it as Malc - designed to stop the crankshaft splitting in two. If you've ever driven a Ford Pinto type engine with a goosed harmonic damper you'll know why the crank cracks
Pinto,your going back a bit nowdandywarhol wrote:Yep, thats what I know it as Malc - designed to stop the crankshaft splitting in two. If you've ever driven a Ford Pinto type engine with a goosed harmonic damper you'll know why the crank cracks
Didn't Tonto ride a Pinto?
Well that's good news (cos its not too tricky to fix) and another success to chalk up to the expert diagnosticians on here. One thing I recall about this problem was that it could be caused by having incorrect belts (wrong V-profile in cross-section) as they effectively exerted too much pressure on the pulley faces and split the thing as a result. Would be worth making quite sure correct belts are fitted as part of the repair (I imagine you'll need new ones anyway).al.b wrote:Hi Everyone
Al
Different Horse Powerfrancophile1947 wrote:Didn't Tonto ride a Pinto?![]()
4 foot drive thoughteenmal wrote:Different Horse Powerfrancophile1947 wrote:Didn't Tonto ride a Pinto?![]()
Thats the mane thingfrancophile1947 wrote:4 foot drive thoughteenmal wrote:Different Horse Powerfrancophile1947 wrote:Didn't Tonto ride a Pinto?![]()
teenmal wrote: Thats the mane thing![]()
I'll give you that one
