If thats the case how come i've not needed 40psi in my front tyres, due to the weight in the front. ( and I dont mean the engine
uneven wear in front tires
- brorabongo
Re: uneven wear in front tires
- You've Been Bongod
blimey i think i should run 1 side on 35psi and the other on 40psi and see which side wears first
I reckon that would have been the cause, don't you? I'm certainly not crying about having the original (steel) 15" wheels, giving a more comfortable ride, better load rating, and the originally designed sufficient grip levels - compared with low profile tyres on bigger diameter wheels. Low profile tyres on big wheels are intended for high performance vehicles, to give increased cornering grip at high speed, while sacrificing comfort, load bearing capacity and bank balance. Is the Bongo a high performance vehicle? Somebody's been doing some clever marketing to the Bongo community IMHObrorabongo wrote:Wonder if my rear tyre wear at 40psi was due to not having enough weight in the back. I'm on 15's.....
they seem soooo small what with you lot talking about 17's and 18's.
No, it's just that bigger wheels look betterRon Miel wrote: Somebody's been doing some clever marketing to the Bongo community IMHO
Well yes, "the tyres ARE cheaper". Assume you don't mean bigger wheels AND bigger tyres but bigger wheels with smaller sidewall width low profile tyres, as above?francophile1947 wrote:No, it's just that bigger wheels look betterRon Miel wrote: Somebody's been doing some clever marketing to the Bongo community IMHO15 inch were probably fitted as that's the "standard" size for vans and the tyres are cheaper.
Yes indeedRon Miel wrote:Well yes, "the tyres ARE cheaper". Assume you don't mean bigger wheels AND bigger tyres but bigger wheels with smaller sidewall width low profile tyres, as above?
Comfort, load factor, cost, marketingfrancophile1947 wrote:Yes indeedRon Miel wrote:Well yes, "the tyres ARE cheaper". Assume you don't mean bigger wheels AND bigger tyres but bigger wheels with smaller sidewall width low profile tyres, as above?I use 225/55x17 tyres that, although they are bigger than the standard tyres, make my speedo accurate, instead of reading higher than my actual speed.
David
Comfort isn't much different to standard tyres as mine aren't very low profile. Cost ain't too bad either, unless you get branded tyres from Kwik Fit - they wanted £183 each for Pirellis
(I didn't accept their offer
With the tyre size I've got, your unlucky to find any with a low load rating - mine are 101
OK John. How about spend more on the motor, and less on modding it? I know it takes all sorts, and I'm really just having a little stir, but my own approach is to get out on the road with minimum mods, minimum add-on cost, and minimum maintenance, if I can. I admit it, I'm lazy and I'm meanfrancophile1947 wrote:Comfort isn't much different to standard tyres as mine aren't very low profile. Cost ain't too bad either, unless you get branded tyres from Kwik Fit - they wanted £183 each for Pirellis![]()
I didn't pimp mine - it was like it when I bought it. The only thing I've done is fit a low coolant alarm and take the rear seats out
Yep. I even knew that - it's in the magazine article isn't itfrancophile1947 wrote:I didn't pimp mine - it was like it when I bought it. The only thing I've done is fit a low coolant alarm and take the rear seats out![]()
on the other hand a nice set of 18's with a chrome lip do look the muts nuts
So does my mota with just a good coat of polishYou've Been Bongod wrote:on the other hand a nice set of 18's with a chrome lip do look the muts nuts
Yea but no but. Although I bought my Bongo so I could 'do lots of stuff', I still regard it as an object of great (potential) beauty, and I've loved doing stuff to make it special. One area that lets the Bongo down 100% in my view is the standard wheel trims. I mean, they are just so DULL
A nice set of alloys sets a Bongo off nicely. Mine came with the beauts I now sport. I meant to sell them to make a bit of dosh (tightness again) but just couldn't do it - they were just so yummy. the rest of my bling is 'practical bling' but its bling nonetheless (right down to the National Trust sticker in the windscreen).
Slurp slobber slobber
- The Great Pretender
Expensive alloys?...............I got a set of pukka Mazda 17" alloys of e-bay for £52.00.Ron Miel wrote:Yep. I even knew that - it's in the magazine article isn't itfrancophile1947 wrote:I didn't pimp mine - it was like it when I bought it. The only thing I've done is fit a low coolant alarm and take the rear seats out![]()
Fact remains that's why i don't see any point in paying the wheel merchants for expensive alloys, etc. Mikeonb4c keeps saying he's mean - he aint seen nothing yet
And no they didn't come from Essex.
Took a couple of months bidding at a price I was prepaired to pay being a tight a**
To infinity and beyond
