which oil 10w 30 or 10w 40 or 15w 40
scanner
Re: which oil 10w 30 or 10w 40 or 15w 40
Post by scanner » Mon Apr 13, 2009 2:16 pm
peanutcrusher wrote:can you get 5w 40 oil and if so would it be a better chose.
If you did it would be "thicker" when warm and could result in higher fuel consumption (lower MPG) as a result of more "drag" inside the engine - unless of course the engine is really worn and loose.
meek.tv
Post by meek.tv » Wed Mar 24, 2010 11:32 am
been looking here for oil http://nielsencdg.co.uk/acatalog/Semi_S ... _Oils.html
Ive used 10w-40 in the past but i notice they now do a 5w-40 that says "turbo" up the side. Would the Turbo version be better suited? Just about getting to 100,000 miles
.......... cycling more.
meek.tv
Post by meek.tv » Wed Mar 24, 2010 11:41 am
just noticed there is a fair price difference, i think that may sway my decision making
Post by mikeonb4c » Wed Mar 24, 2010 1:10 pm
Trouble at t'Mill wrote:Clearly the Bongo is a tolerant beast!
5W 30 is pretty thin, and would be ideal for colder climes and, I guess, short runs as mentioned above. Has anyone using this grade noticed if the oil consumption has gone up?
I'd be very surprised indeed if using 10W 30 or 40 oil caused a significant increase in fuel consumption over 5W.
For normal driving and/or motorway runs, I'd rather stick with 10W.
I love the way this forum software doens't flag up new post of interest. Just to answer this, I see it t'other way round. I was told long ago that a very large proportion of engine wear happend in the 1st 2 mins of running, due to sluggish circulation of cold viscous oil. So that why I prefer a thinner low end spec if my Bongo is doing 2 x daily 5 mile runs. Its never really going to get to the upper end (30/40) bit. Effect on fuel consumption is probably minimal, but must be theoretically true so mentioned for fun.
As far as the Bongos other life is concerned, its on the open road doing 200rpm @ 65mph and with plenty of engine cooling (provided system is healthy). I think 30 is a safe bet for that in UK climates. The only time it is inferior is in heatwaves, lots of hard work in the hills, towing heavy loads, or sat in motorway traffic jams maybe.
I'd love to use 5W/40 but its a lot dearer. Life's a trade-off I guess.
TBH I can't think it matters that much which you use, but might as well consider what kind of lifestyle your engine is likely to have and base decision on that.
mikexgough
Post by mikexgough » Wed Mar 24, 2010 1:17 pm
I put some 5/30w in at the last change.......in October 09.... Wilkinsons semi synthetic....yep Wilkinsons....
Bongo is due a change in April, so I will be visiting Peterborough before then and will use my normal Fuchs 5/30w
Post by Northern Bongolow » Wed Mar 24, 2010 1:45 pm
millars 5w 30 semi synthetic,every time look at the spec ont tinternet. :D :D
scanner
Post by scanner » Wed Mar 24, 2010 2:19 pm
meek.tv wrote:just noticed there is a fair price difference, i think that may sway my decision making
Not if it costs you a turbo it shouldn't.
Good oil is cheaper than a turbo.
dreamwarrioruk
Post by dreamwarrioruk » Wed Mar 24, 2010 3:30 pm
i have always used 5 30 in ours except for once when i had to use some 10 40 soon got drained out as i couldnt afford the increased cost in fuel due to the drag increase in the engine.
mike, jo and emma
Post by mikeonb4c » Wed Mar 24, 2010 3:35 pm
dreamwarrioruk wrote:i have always used 5 30 in ours except for once when i had to use some 10 40 soon got drained out as i couldnt afford the increased cost in fuel due to the drag increase in the engine.
Now that's interesting. Not having tried 10/40 I've never had the chance to do a comparison so thought it best to yield on that point, but now....... :roll:
dreamwarrioruk
Post by dreamwarrioruk » Wed Mar 24, 2010 3:36 pm
i cant guarentee it but i reacon we lost around 4 mpg just with the change in oil. hence why it was dropped asap and i used it a a flushing oil.
mike, jo and emma
scanner
Post by scanner » Wed Mar 24, 2010 4:25 pm
For main running (not during warm up) it is the 30/40/50 number that defines viscosity and thus amount of internal "drag" in the engine.
The higher that number the thicker the oil should stay when hot.
5w/40 is (roughly) 33% thicker than 5w/30 and will result in proportionally more internal "drag".
eckerB
Post by eckerB » Thu Mar 25, 2010 4:20 pm
I tried a 10/40 oil and found that the mpg dropped.Back on 5/30 now(Fuchs full synthetic) about £17-£18 for 4 litres.Much better on fuel again. :)
brorabongo
Post by brorabongo » Thu Mar 25, 2010 4:57 pm
I'm still on Magnatec. When I first used it I noticed a marked difference in engine noise (quieter), and fingers crossed it's protecting from the moment you turn the key, as they say. Also noticed that the oil lasts alot longer therefore less changes. \:D/
ボンゴの激怒 pictures
Post by rita » Thu Mar 25, 2010 8:33 pm
brorabongo wrote:I'm still on Magnatec. When I first used it I noticed a marked difference in engine noise (quieter), and fingers crossed it's protecting from the moment you turn the key, as they say. Also noticed that the oil lasts alot longer therefore less changes. \:D/
I use Magnatec also £26.00 for 8 litres at Costco.
splitpin
Post by splitpin » Thu Mar 25, 2010 10:02 pm
Our local ASDA was selling Castrol GTX Diesel 10/40 at £3.50 for a 4litre tub, bought five tubs. good bargain. I average just over 30mpg on the 10/40 so maybe I could get around 35mpg if I switch to a 5/30 grade if your figures are accurate dreamwarrior.
dreamwarrioruk wrote:i cant guarentee it but i reacon we lost around 4 mpg just with the change in oil. hence why it was dropped asap and i used it a a flushing oil.
