http://www.medhelp.org/posts/Respirator ... how/660683
Like any worn out component, i would imagine it's failings would become more apparent under duress & continue to progress...kelv wrote:Could have been I suppose.jaylee wrote:Could it be one of the belts slipping?
They look to be adjusted OK
Is there a reason why a belt should slip only under load ?
Exactly the same symptoms, and and the same cure as mine.tomsk wrote:Hi Kelv
I do a fair bit of touring in Europe, and have the same problem. If I leave it in drive on mountain passes, I get the clutch burning type smell?
I just use the gearbox or hold button, and no more problems.
Regards
Tom
