Page 2 of 2
Re: Squeaking from Turbo is driving me mad!!!!!!!
Posted: Tue Jul 21, 2009 4:43 pm
by waycar8
mister munkey wrote:
mister munkey wrote: My money is on you & me having the same problem. Luckily, I have a spare turbo (courtesy of Wayne - again) & will get it sorted over the weekend.
I'll keep you posted as to how I get on.
8)
Stand By Your Beds!
Turbo checks out as okay.
Its the exhaust manifold gasket on mine.
So why you burning oil! :? :?
Posted: Tue Jul 21, 2009 5:45 pm
by mister munkey
Dunno. :?
Possibly rings?
Leaving it with Dave Benson Thurs & Friday for noises to be sorted, rear ARB bushes & general health check before setting off for Harrys do.
Posted: Tue Jul 21, 2009 9:29 pm
by clogger
ok here`s another squeak/squeal one for ya and i don`t mean mice
cold engine no worries nothing
go for a drive nothing
stop for a while so everythings warmed up nice
start off nothing
hit 2500-3000 revs have squeal for a few seconds then stops may do this a couple of times
but is intermitent
has just started over the last couple of weeks but does`nt seem to be getting worse and everytime i try to get it to do it stationary to suss out exactly where it is it won`t play the game
ideas welcome
cheers
Posted: Wed Jul 22, 2009 5:03 pm
by waycar8
I would say one of your belts is starting to slip, or worst you have a pin prick hole in a hose and its squirting near the alternator belt, have a good check but I would go with my first sugestion, mine did that little sqeel on startup then disapeer straigh away then come back when i put my foot down but once engine was warm it stopped, but got worse over a few weeks, tightend em up which stopped it for a couple more weeks but started again so repleced them all and its been fine ever since.
Posted: Wed Jul 22, 2009 5:09 pm
by missfixit70
Try a wee squirt of wd40 on the belts to see if it makes it disappear, it's not a solution, just a way of checking whether it's the belts or not. Be careful you don't overtighten the belts, if that's what it looks like.
Posted: Thu Jul 23, 2009 6:04 pm
by z00non
clogger wrote:ok here`s another squeak/squeal one for ya and i don`t mean mice
start off nothing
but is intermitent
ideas welcome
cheers
Would sound like a snapped/loose manifold stud to me. Not too hard to get manifold heat shield off just pop off the pipe on the front of the turbo to give a bit more room then look for said hole with no stud & also check there tight. If you try WD40 on your belts watch where your spraying it especially around the back of your alternator .. :!: :!: :shock: :!: :!:
