Glowplug Light and Fuses
- westonwarrior
Re: Glowplug Light and Fuses
The answer is both probably make the glow plug light flash if there is a problem
the warning system on bongos are very strange so if the light flashes it could be either sensor or connector scavenger (next to handbrake) or rad fan ( block )
they are also probably linked in some way
Hey don't forget the connector just behind the bottom edge of the steering cowl Rob!
Yes, there are two paths you can go by
But in the long run
There's still time to change the road youre on.
OOOOH... It makes me wonder....
But in the long run
- westonwarrior
do you often quote Rolf Harris?
two little boys?
two little boys?
I gotta flashing glow light on my 3 litre roo...
Can you guess what it is yet?
kelv
I thought you would have had the answers toomissfixit70 wrote:Start a different thread to answer those questions (or do a search - the answers are out there if you are that interested), refer to the original query & my comments about keeping it on track please.
Never mind.
kelv
Thanks, a useful answer.westonwarrior wrote:The answer is both probably make the glow plug light flash if there is a problem
I do have another idea...!
It could be that old family favourite...
Um diddle iddle iddle um diddle eye!!! The old fault code... As i travel down the frog & toad..
What i get is an old fault code.....
kelv
Have you got one for Jake the Peg as well ?jaylee wrote:I do have another idea...!![]()
But make it on topic for crying out loud , anybody got any Meerkats ?
Don't tell me your still trying to sort out the cruise control & you need an extra leg...!kelv wrote: Have you got one for Jake the Peg as well ?
kelv
Nope, I binned that heap of junkjaylee wrote:Don't tell me your still trying to sort out the cruise control & you need an extra leg...!kelv wrote: Have you got one for Jake the Peg as well ?
Couldn't get it to remove the Mondeos that kept cutting in front of me and making me switch it off
This may be of interest - http://www.igmaynard.co.uk/bongo/forum/ ... an+testing, Dandy & G8DHE's input about halfway down the 3rd page in particular - highlighting the complexity of the fan trigger system.
If sensors & connections have been checked/replaced & any other suggested causes checked, then the next logical step is to use the Diagnostics factsheet or take it to a garage that can plug in a OBD II Diagnostic jobby IMO.
kelv
Yes, probably not worth messing about shorting out sensors to check the operation of the scavenger fan thenmissfixit70 wrote:This may be of interest - http://www.igmaynard.co.uk/bongo/forum/ ... an+testing, Dandy & G8DHE's input about halfway down the 3rd page in particular - highlighting the complexity of the fan trigger system.
To test mine, I got the engine hot, then unplugged the sensor.
The glowplug light flashed a bit, then the rad fan cut in, followed by the scavenger fan, which could be seen but not heard.
I guess that it is working as it should be, and you would probably never know with the seats down.
A flashing glowplug light does in some way seem to be linked to the fan sensor.
Mine stopped flashing again when the sensor was plugged back in.
In case anyone is looking for this info in future, I understand that the photo in THIS LINK (from 'stilldesperate') is the scavenger fan sensor. The one in THIS LINK is the engine cooling (radiator) fan sensor.
kelv
Thanks for pics
- westonwarrior
Depends what the pictures are of
Thats why I stopped getting the Sun it didnt help my reading at all.
I do think that little comments in other wise reasonable questions and answers are unnecessary and are getting noticed.
