The symptoms are consist to when I had one in the past on V engine.
Have you checked for one
Hope you sort it
Jamie - I've not read through this thread carefully so apologies if already said (although I knhow you have mentioned it above), but I recall Apole (Andy) and also I think cheffy (both these guys have V6s) having issues not too dissimilar and the cure was a new distributor head etc. Try PMing them if they don't chip in on this thread. Good luck - keep us postedhogggman wrote:hi all,
sorry for the long delay,but i`ve not used the bongo much recently,having started walking to work,but today i decided to test the (fairly new)lambda sensor.armed with a multimeter i checked it out,and it was giving a reading of between 0.4 and 0.8 volts,changing several times a second.from what i had read on google,that seems fairly normal.one helpful site had various pics of sensors in various conditions,and mine seemed a little sooty,which is caused by the engine running rich,according to a pic of a similar-looking sensor.
as i now seem to have eliminated the lambda senor,does anyone have any suggestions at to what i should try next?i changed the spark plugs a year ago,and definitely the problems occurred way after that,but i don`t see a connection there.when the engine seems to falter or hesitate at about 50mph or 2000-2500 rpm,i have to put my foot down a little to get past it,and very often,there`s a muffled`pop`from underneath,then the bongo is back up to speed again.if the bongo had a leak in a vacuum pipe somewhere,would it cause the engine to run rich or weak?
any suggestions?i`d be very grateful.in the new year,before mot time,i may change the plug leads/distributor cap anyway,but i always hope for a simple answer first.
thanks
jamie
If you have difficulties locating the cap & arm, the Bongo Shop should have them back in stock by the end of the week. See here (non members)hogggman wrote:hi,
or this for the cap and rotor..........$60 including shipping.i wonder if it`ll fit?
http://www.rockauto.com/catalog/raframe ... ttype=7054
thanks
jamie
