That's a reasonable price range that i've heard being bartered about a fair bit.Aethelric wrote:
I have been quoted £1000 to get it fixed, or £1500 if it needs a new head (all plus VAT). Is that a reasonable price?
With your stat removed i assume that your top & bottom hose remain at pretty much the same temp under normal running? (with stat in place, top hose hot, bottom hose warm?)
Of course i stand to be corrected on this,but i'm guessing the placement of the stat in the location it is in factory form is where the mazda techies though best for the engine to reach full operating temperature in a reasonable amount of time, effectively the closed stat leaves 2/3 's of the complete cooling system to do its thing, (effectively aiding OT status quickly) Then, when the temp sensor senses 82c, the stat starts to open, giving the "full" range of cooling, by opening up the usually redundant 3rd of the rest of the cooling system... This is great if the temp sensor, stat are operating as they should be... The thing is, we that browse the forum regularly are quire aware that bongo's can have cooling related issues if a wary eye isn't kept on them... All it needs is a faulty temp sensor, or sticking stat to cause bigger issues. Does your average joe really know if the rad fans/stat opening procedure is actually taking place?
In my experience, removed stat causes slow OT status to be achieved, this can cover up issues elsewhere that need addressing... I suppose the question is,is it actually really necessary to have the stat fitted at all? The temp sensor (if working correctly) kicks the fans at a predetermined temp anyway, why only have 2/3rds of the system "online" 90% of the time if all the system being open is a more effective cooling system? (other than the initial quicker temp from cold start issue) I'm no expert by a long chalk on this subject,all the above may well be fundamentally flawed in it's concept.
