I never moved my pump I did it in situ without moving the mounting bolts as per fact sheet......I need to get the solenoid off to check operation as if you see the 1st symptoms.......it cut out then restarted of sorts, my thinking was crud in the fuel filter as Bongo had been up on jacks while I was doing the spring assisters.....I am going with the solenoid tomorrow when I have got a spanner, if that is eliminated......I need a pump and a garage to fit......then of it can't be done by Thursday......change my bookings and book a hotel........Javelin wrote:Sounds like I have a similar if not identical problem.
Leaking seal on the pump.
Undid the mounting bolts twisted the pump round, got access to the plate.
Changed the seal.
Put everything back and......... no go.![]()
Foot down on the throttle and a full battery of turning over and nothing.
Dropped a couple of fuel lines off to see and nothing comes out.
Is there a bleed bolt/valve etc?
On my marine diesel I have to bleed the fuel system but I can't see anywhere obvious on this pump.
The pump was fine two days ago, all I've done is change the seal.
I assume that the position of the pump is a timing issue and shouldn't effect the actual pumping performance even if I've not got it back spot on.
Grr.... not starting
- mikexgough
Re: Grr.... not starting
- dandywarhol
Pump timing is now out - this needs to be very acurately retimed with a DTI gauge to the nearest 0.10mmJavelin wrote:Sounds like I have a similar if not identical problem.
Changed the seal.
Javelin
But even so the pump should still pump should it not?Javelin wrote: Pump timing is now out - this needs to be very acurately retimed with a DTI gauge to the nearest 0.10mm
- dandywarhol
Yep, it will pump but inject at the wrong time - is there fuel coming up if you open an injector pipe slightly?
- mikexgough
looking at the Fuel Cut off solenoid jobby.......in case I need to get one.........
is this...
.. at £9.99.......
the same as this..........
at £61.53
The first is a generic Bosch and the other is from Bongo Bits......which I would assume would be pukka Jap..?
is this...
at £61.53The first is a generic Bosch and the other is from Bongo Bits......which I would assume would be pukka Jap..?
- dandywarhol
Its a Zexel pump, made under licence from Bosch- I know which I'd choose
When you take the old one out, reconnect the wire and earth the body - it should lift the plunger when the "ignition" is switched on
- mikexgough
Thanks for the heads up Alan..... will do in the morning...
- mikexgough
Well the fuel cut off was fine, I did however try it without the plunger , just to see......... still no go ...... oh well off to a Bongo garage...... needs a pump.....as all the usual suspects have been inspected/changed
did you check for obstruction in the pump when you removed the Solenoid,IE bits of rubber etc.
Sometimes the outlet orifice can get blocked.
- dandywarhol
I'll probably be proved wrong here but its very unusual for a pump to suddenly fail (unless it has seized) Is there a 12v supply going to the solenoid when the ignition is on?
Javelin
I'm trying to get my head round how the pump actually works.
Given that the fuel supply is below the pump how does the pump prime?
If it's a centifugal pump I can't see how it would self prime.
If I pulled off the supply hose and gravity fed the pump would this help clear airlocks and refill the pump system.
- mikexgough
Yes there is a 12v supply....and the solenoid works.....dandywarhol wrote:I'll probably be proved wrong here but its very unusual for a pump to suddenly fail (unless it has seized) Is there a 12v supply going to the solenoid when the ignition is on?
- mikexgough
rita wrote:Hi,
Yes did that too.....
- mikexgough
It has been suggested that the cam belt has "jumped a tooth".....ot the tank is crudded up ......
Still, it's going to be taken to the garage.....I can't be ar**ed to play anymore....
.and I'm off to Holland Thursday....in a Citroen and staying in a hotel instead of off in a Bongo and sleeping in my Bongo....
Bummermikexgough wrote:It has been suggested that the cam belt has "jumped a tooth".....ot the tank is crudded up ......
.and I'm off to Holland Thursday....in a Citroen and staying in a hotel instead of off in a Bongo and sleeping in my Bongo....![]()
