I'm back.widdowson2008 wrote:Driver side links look fine.dom_e wrote:okay, I've done some further investigation on the linkages etc...
The linkages seem to be intact and move when different settings are used.
The passenger side one, doesn't seem to move on any setting though.
http://www.flickr.com/photos/dom_eggbee ... otostream/
Am I expecting too much from the window de-mist or is there likely to be a problem?
Dom
Not sure what the other link on the passenger side does - I'll go and check mine to see if it moves when the controls are operated. I'll be back!!!! as the man said
The controls don't seem to operate anything in the passenger side (on mine anyway)
BUT I took another look at your driver side linkage and there is an arm missing on yours on the link at 1 o clock. The rod is there but there is nothing attached to it.(extreme top right end of link) Therein lies your problem I reckon. Can be moved manually until you get a replacement arm (or find the one that has dropped off!!!!!!)
I'll doctor some pics and add to post.
