HI BOBNGO,I NOTICED THAT YOU (QUOTE)bobngo wrote:as a reminder this glorios bongo has been parked up for 3 months ,due to me/hospital/recovery.
but will now not move ,its wt 2.5 auto.
several members suggested that i should check each wheel for stuck brake, which i did , and all wheels are free ,well they move by the amount of slack in the transmission, (why wo,nt they rotate 360 degrees by hand even in nuetral ?) but the van still wo,nt move , it tries to ,moves about the distance of the slack in the system ,then stops.
tried forward/reverse/forward/reverse , rocking it but that is no help
there are sooooo many "safety lockouts" on this van have i missed one maybe ????
it was all working perfectly before being parked up .
can anyone help please ????
i
several members suggested that i should check each wheel for stuck brake, which i did , and all wheels are free ,well they move by the amount of slack in the transmission, (why wo,nt they rotate 360 degrees by hand even in nuetral .
Have you tried jacking 2 wheels off the ground at a time,ie rear then front.
