Yes you can, it slides up leaving the screen mount in place, but it's held in situ by a spring clip, you'll see a small cutout/hole on the bottom of the mount just off centre, stick a small bladed screwdriver or stiff coathanger type wire ot similar up the hole & you'll feel it encounter resistance, a bit more pressure & you'll feel it move the spring, then the mirror should slide up the mount & off.bongomadness wrote:Hi its me again.Does anyone know if you can take of this mirror from its holder which is glued to windsc reen?????? Our mirror is discoloured around the edges and i have just found one on ebay but thought i would get advise here first......dont want to crack the windscreen in the process lol
I've just learnt something new (2 things with the vanity mirror
