Cooling system pressure test kit anyone? DO NOT DELETE
jumper
Re: Cooling pressure test kit anyone?
Post by jumper » Wed Mar 10, 2010 12:17 am
he uses the 2 systems, the pressure test to test the system and the vacuum to refill
Happiness isn't having what you want its wanting what you have.
falcoron
Post by falcoron » Wed Mar 10, 2010 8:28 am
How does that work when you need the stat to open? shoot me if im thick!
Driver+Passengers
Re: Cooling system pressure test kit anyone?
Post by Driver+Passengers » Fri Nov 23, 2012 8:11 pm
DO NOT DELETE?
Edit: Sorted :)
Image Image
Bogmonster40
Post by Bogmonster40 » Fri Nov 23, 2012 8:57 pm
excellent post, u could not have made it any easier.....
V6 2.5i Tintop Aero Petrol/LPG
Toby&Jules
Re: Cooling system pressure test kit anyone? DO NOT DELETE
Post by Toby&Jules » Fri Nov 23, 2012 11:11 pm
Indeed. Ours is still hibernating, but the more I read, the more paranoid I get about leaks. I just want Bongo ownership to be a happy experience for us both. Definitely gonna be doing this shortly.
Regards
Toby
Post by Northern Bongolow » Fri Feb 01, 2013 12:23 am
a spin on this tester is to put the gauge in line and use a flat cap to test.
put the gauge on a t piece, then put half the pipe on either side of the t piece, then get a standard cap and remove the seal, this gives easier pressure readings.
when your happy with it you could fit it to the end of the bleed pipe, then put the gauge in the cab, then you have constant pressure monitoring. :wink: :)
Driver+Passengers
Post by Driver+Passengers » Fri Feb 01, 2013 11:55 am
Northern Bongolow wrote:a spin on this tester is to put the gauge in line and use a flat cap to test.
What, so you look like Fred Dibnah while doing it?
Image Image
Post by Northern Bongolow » Fri Feb 01, 2013 7:52 pm
some would say i dont need the cap to do that matt. :lol: :lol: 8) .
ps. have you got a light for this woodbine :wink:
