CAMBELT / FUEL GAUGE - DOES A WORKSHOP MANUAL EXIST ?
Re: CAMBELT / FUEL GAUGE - DOES A WORKSHOP MANUAL EXIST ?
Post by mikeonb4c » Wed Jun 09, 2010 11:37 pm
jaylee wrote:
mikeonb4c wrote:
The only problem is if the sender connector block is not making a good connection to the tank (which the factsheet seems to say can be the problem as that is how it starts the connection to vehicle earth). In that situation, I guess the underbody technique wouldn't help, unless I've misunderstood something. Anyhows, I now have a wire from the connector block to the chassis, which I hope will cover all eventualities.
It will! :wink: The general consensus is earth through the screws on the tank cover.. But what if the tank don't ground properly?? All you did was cut out the middle man... :D Unless i'm wrong about the tank!? :-k
that's what I reckoned - its good to have confirmation :D
Bongo13
Post by Bongo13 » Fri Jun 11, 2010 8:41 pm
Has anyone heard of a "SUN CAMBELT " which has made in japan stamped on the belt and the box and this is the reason I bought it but comparing it with the one I have just taken off and which apparently has done about 50K mls it seems unbelievable flexible to me .
