Page 2 of 2
Re: Radiator advice
Posted: Fri Jun 25, 2010 1:36 pm
by missfixit70
mikexgough wrote:
missfixit70 wrote:Make sure the oil cooler connections are screwed tightly into the borrom of the rad, my recently fitted JAS rad seems to have developed an ATF leak on the passy side joint, have to get the intercooler scoop off tomorrow to have a proper look.
Mine were loose when I got mine and as I noticed I nipped them both up prior to fitting..... :wink:
So did I :roll:
Re: Radiator advice
Posted: Fri Jun 25, 2010 1:40 pm
by missfixit70
Sluggy wrote:can I see these connections from under the front bumper?
Just above the plastic scoop going into either side of the bottom of the rad.
Re: Radiator advice
Posted: Wed Jun 30, 2010 9:23 pm
by Sluggy
I checked with my mechanic about these connections, he did indeed have to tighten up the connectors also, but he said this is normal so that you can angle the connector in the right direction before tightening.
Maybe this little nugget needs adding to the radiator fitting fact sheet done by harry as many 'amateurs' might miss this?
Re: Radiator advice
Posted: Wed Jun 30, 2010 9:26 pm
by missfixit70
Email [email protected] with it & then it can get added in, don't count on him reading every post on here to update the factsheets info.
Re: Radiator advice
Posted: Fri Jul 16, 2010 9:29 pm
by vanvliet
David Edwards wrote:If you look on the thread below re radiator I have put a link to a company I got mine from, superb at £111.00 delivered with a two year warranty.
Took your advice - pleased :) My mechanic says that it is good rad.
Used Mazda replacement stat. New mazdaparts water pump /timing belt with tensioner, change oils filters . Previously changed some dodgy pipes for silicon ( no probs, but should have gone for standard rubber ones because the clips bother me ) Temp and water level sensors fitted
All preventative stuff .
Runs at 12 noon with 12.05 reading after motorway jaunt at 70-80 on three hour round trip.
Re: Radiator advice
Posted: Tue Jul 20, 2010 9:51 am
by mikexgough
vanvliet wrote:Runs at 12 noon with 12.05 reading after motorway jaunt at 70-80 on three hour round trip.
Just how they should run.... =D>
Re: Radiator advice
Posted: Tue Jul 20, 2010 11:03 am
by scanner
But only if they have a modified temp gauge..................
Re: Radiator advice
Posted: Tue Jul 20, 2010 12:30 pm
by rita
I have often wondered Why Mazda and others Doctored the Temp gauge when they only showed 12 noon ie (half full position).in the original state.
Just seems a bit strange..
Re: Radiator advice
Posted: Tue Jul 20, 2010 12:45 pm
by missfixit70
Because the temp gauge moving scared people, so it was dumbed down so it didn't move once it got up to temp during "normal" operating range.
Re: Radiator advice
Posted: Tue Jul 20, 2010 3:38 pm
by mikexgough
#-o #-o and there was me assuming people would know what I was on about........ #-o #-o should have known better.....
Re: Radiator advice
Posted: Tue Jul 20, 2010 5:17 pm
by Alacrity
I used a company called Brighton radiators (I think they are part of a nationwide group) on 01273 611102 & got my rad for £147.00 + vat & it was spot on. No connections that need blocking off with a bit of hose, 2 clips & a bolt (another potential water leak :evil: ) & oil cooler connections that were tight & leak free. Did just what it said on the tin. Bleed it out with a vacuum bleeder, job done & forgotten. Easy. 8)
Re: Radiator advice
Posted: Wed Jul 21, 2010 12:04 am
by scanner
mikexgough wrote:
scanner wrote:
mikexgough wrote: Just how they should run.... =D>
The trouble comes when someone who hasn't fitted a Mason (or similar), takes your word for that and worries why their's sits for ever @ 11 o'clock and then doesn't worry when it goes past 12 o'clock.
