Page 2 of 2
Re: Removed roof bars - now have holes in roof!
Posted: Tue Aug 10, 2010 2:29 pm
by mikexgough
dandywarhol wrote:The "female" roof inserts are screwed into a "nut" which fits from the inside - this can work loose - tighten the "nut" from underneath the roof and the inserts won't come out or leak water
One to remember there Alan...... especially for those with roofbars......as utilising the roof inserts may in some cases "loosen" them to a degree when said roof bars are removed...... has to make you wonder if there is any merit in "nipping" the inserts up before fitting roof bars ......
Posted: Tue Aug 10, 2010 7:18 pm
by mikexgough
had a reply on this....... roughly translated......
Q.
AFTの上にボルトの穴が4ヶ所ありますがあれって何 What is AFT have any place on the 4 bolt holes
A. A.
あれは「AFTの整備の時、専用工具をくっつけてクレーンで吊るための穴」だそうです。 That "AFT at the development of holes for hanging with the crane sticking a special tool" is Dasou. フォードのおにいちゃんが言ってました。 Cha did not have to go all your Ford.
AFT自身は重量が65Kgあるそうで、とても人間がひょいひょい扱えるものではないため、付け外し整備用についているとの事です。 AFT itself so that the weight 65Kg, not a man to be treated very Hyoihyoi is that thing off with just for the maintenance.
Posted: Tue Aug 10, 2010 7:23 pm
by francophile1947
mikexgough wrote:had a reply on this....... roughly translated......
Q.
A. A.
Of course - why didn't we think of that
I think it was the Hyoihyoi that caught us out
Posted: Tue Aug 10, 2010 7:33 pm
by Triple/R
Q.
A. A.
Well it's as clear as mud now innit!~i bet you think were a thick lot on here
Posted: Tue Aug 10, 2010 9:32 pm
by hembramacho
munroman wrote:8mm bolts will screw into them, but the holes don't go through the roof, try putting a match down the hole and you will feel that it stops partway down, so you won't get lots of water running through.
Mine did as the other bit became loose and dropped out, which is why I was originally concerned!
munroman wrote:
If you are ever thinking of putting roof bars back on, let me know, as I think I might have a solution which would allow you to have roof bars when required, without getting in the way of the AFT cover.
I'd be interested in your ideas on that!
Andrew
Posted: Tue Aug 10, 2010 9:36 pm
by hembramacho
Ah - that makes sense now, although I think you can tighten the 'nut' from the top of he AFT, as trying to access it from underneath is a nightmare!
Andrew
Posted: Tue Aug 10, 2010 9:56 pm
by missfixit70
But you will probably still need to hold the nut underneath, ideally you don't want to be turning the inserts as I think they are bonded in as well?
Posted: Tue Aug 10, 2010 10:06 pm
by hembramacho
missfixit70 wrote:But you will probably still need to hold the nut underneath, ideally you don't want to be turning the inserts as I think they are bonded in as well?
I think one of mine may have come unbonded then - probably due to me turning it from above.
It's a bugger though to get your hand in underneath to hold it in place!
Andrew
