Page 2 of 2
Re: Air Conditioning - not much heat from it
Posted: Thu Dec 09, 2010 7:41 pm
by B*Witched Blingo
This last week or so I have been using my hubbies beastie (2.5 diesel) and I thought that his heater was not as warm as mine (2.5 Diesel). I then remembered that we had switched the switch from outside to inside to recirc as I find it defrosts his windscreen quicker (don't shout, it works a bit better for us). Just check that the recirc button hasn't been depressed. It makes a heck of a difference to the heat brought into the cab.
Posted: Thu Dec 09, 2010 7:51 pm
by jaylee
B*Witched Blingo wrote:Hi,
True! :wink: The recirc on my manual controls when pushed to the screen does seem to heat things up/melt a little quicker... Could have some thing to do with slightly warmer air in the cab than outside..? (Draws air in the cab under the glove box.)
However i do find if the recircs left on too long it can start to fog up around the A pillar windscreen aria, door windows & quaterlights... It soon clears when pulled through from the front! :D
Posted: Sat Dec 11, 2010 10:37 am
by Tripewriter
I go with Haydens reply as that fits my circumstances.
However under the bonnet there is the intake for the heater matrix on this there is a Flap with a winter position and a summer position. The winter position restricts the air flow.
Posted: Fri Jan 21, 2011 8:10 pm
by ROXY
Just got the Bongo back from the garage - all fixed. The problem was a broken thermostat which is situated near the engine hose under the bonnet.
Thanks for the all the replies
Regards
Roxy
