To harness the electricity, you must first become the electricity.
Replacement Rear Fog blowing fuse
Re: Replacement Rear Fog blowing fuse
I believe you can get the electricity to do whatever you please, provided that you stare at it long enough, hope hard enough and believe in yourself.
'Vincent' - 1996 P reg - Green - 2.5 TD - 4WD - Likes: Diesel, Bitumen and Snow.
eppiblue wrote:I believe you can get the electricity to do whatever you please, provided that you stare at it long enough, hope hard enough and believe in yourself.![]()
This dude does all the work on my Bongo...
He reckons if you were to totally gut the plastic lamp box, leave the lens off & just put some of this stuff around the outer edge...!!??
You can tell the MOT tester its an event horizon around a black hole!!!
You did and you always will 100% of the time.bigdaddycain wrote:And i thought i'd always dropped lucky with "guessing" the connections were the correct way round!
Get in!scanner wrote:You did and you always will 100% of the time.bigdaddycain wrote:And i thought i'd always dropped lucky with "guessing" the connections were the correct way round!
