Page 2 of 2
Re: How close to disaster,,,,,,,,,,,,,,,,,,
Posted: Sat Mar 05, 2011 7:45 pm
by Barrington
Posted: Sat Mar 05, 2011 7:47 pm
by chakota
Posted: Sat Mar 05, 2011 7:53 pm
by Barrington
Posted: Sat Mar 05, 2011 8:29 pm
by briwy
Not sure about using a stainless bolt Barrington.
Size for size stainless doesn't have the same tensile strength as steel. I would be tempted to get to an engineers supply place and get a high tensile bolt with a nylok nut.
Posted: Sat Mar 05, 2011 8:50 pm
by dandywarhol
Barrington wrote:Right just an update on closer inspection the bolt i removed earlier today that held the spline in place was worn on the inside just at its middle point it must have been loose and wearing out for a while enableing the spline to work loose and rattle about in its housing and do its worsed on the original bolt, scary really just one of those things i guess,,,, so i changed it for a hardend stainless bolt, this is now on my monthly check list
could of been a terible ending but all sorted now thankfully
don't know what you're worrying about - it would only have vibrated out on a pothole - not many of them around these days
Well spotted!
Posted: Sun Mar 06, 2011 10:10 am
by helen&tony
Hi Barry
A bit late, but as I promised a photo. today, here it is:
That's 3.75 Cm. of spline sticking out the top.
Anyway, I'm glad you sorted it....What a chilling thought...I have some work to do on our steering...not sure if it needs a new rack yet, but I have a shipment of various parts coming over from Allan's ...and once I have replaced the water-pump....then it's steering...track-rod ends and rack gaiters, and rear A/R bar...droplinks/ bushes and brackets, and front brake-pads.
Once the water-pump is done, that's all the cooling components changed..except the rear heater...and that's getting done in spring...All the suspension is new, with just shockers remaining...then it's down to overhaul of electrics...Transmission was done a few years back, and due for another cleanup...new cambelt........OH when does it stop!!!
Anyway...I'm glad you brought the steering to all of our attention!!!!!
Posted: Sun Mar 06, 2011 11:51 am
by Barrington
Good call i will get onto a high tensile bolt asap many thanks
briwy wrote:Not sure about using a stainless bolt Barrington.
Posted: Sun Mar 06, 2011 11:52 am
by Barrington
Lol cheers Alan
dandywarhol wrote:Barrington wrote:Right just an update on closer inspection the bolt i removed earlier today that held the spline in place was worn on the inside just at its middle point it must have been loose and wearing out for a while enableing the spline to work loose and rattle about in its housing and do its worsed on the original bolt, scary really just one of those things i guess,,,, so i changed it for a hardend stainless bolt, this is now on my monthly check list
Well spotted!
Posted: Sun Mar 06, 2011 11:53 am
by Barrington
Posted: Sun Mar 06, 2011 11:54 am
by Barrington
