What have I done?
Cobra the 1st
Re: What have I done?
Thanks everybody for your posts. Have sorted it.
thedogsbollox
- Tribal Elder
So, you gonna tell us what you hit?
Cobra the 1st
Frightenly nothing, the previouse owner did a bad weld job yey!
Cobra the 1st
Was a bit concerned with some of the other posts I recived with regards to the shock absorber. I've had the bongo for five months without a hitch bar yesterdays fun. Getting ready to take the family holidaying very soon. Also could anyone tell me how to flush the power steering fluid and is slick 50 power steering fluid recommened? I do have 10w/40 as recommended by the bloke at Halfords but I was thinking about the seals?
- daveblueozzie
You need DOT 4 power steering fluid.
Dont know how to flush the brake fluid ,am only doing mine this weekend, trial and error
EDITED.... DOT 4 IS BRAKE FLUID
, NOT POWER STEERING FLUID
, WHICH IS DEXRON 3.
Lost without my Bongo.
I think DOT4 is brake fluid Davedaveblueozzie wrote:You need DOT 4 power steering fluid.
You should use Dexron 3 (or equivalent) automatic transmission fluid for the power steering - same as in the gearbox.
This is asking about power steering fluid, which is usually topped up with Auto Transmission Fluid (ATF).Cobra the 1st wrote:Also could anyone tell me how to flush the power steering fluid and is slick 50 power steering fluid recommened?
But here you mention 10W/40 which is engine oil..............I do have 10w/40 as recommended by the bloke at Halfords but I was thinking about the seals?
Cobra the 1st
The stuff I've got from halfords says power steering fluid on the bottle?
Cobra the 1st wrote:The stuff I've got from halfords says power steering fluid on the bottle?
But not 10W/40??
It could be oil from the Damper.jaylee wrote:Like you Kris, i have a limited knowledge of these matters... But like Scanner am quite interested how this damage came about..?
I'm looking at this picture & also thinking possible damage to any bearings..? & could that be brake fluid on the inner wheel rim??Techies knock me back if i appear to be wrong, I'd check the tire walls too!??? Cant be too careful...
Yes, hydraulic fluid as used in the automatic gearbox. have a qucik look on the blurb on the rear of the bottle before you add any... DEXRON3 rating would be nice to see.Cobra the 1st wrote:The stuff I've got from halfords says power steering fluid on the bottle?
Cobra the 1st
Thanks for all your help guys.
