Page 2 of 2
Re: V6 overheating
Posted: Wed Sep 07, 2011 2:45 pm
by bongomike
I'm actually going to do a coolant change on my v6 this weekend, how do I know when the stat is open?
Re: V6 overheating
Posted: Wed Sep 07, 2011 2:46 pm
by missfixit70
Bottom hose gets hot, same as the diesel I think.
Re: V6 overheating
Posted: Wed Sep 07, 2011 2:53 pm
by bongomike
Ok cool, pretty scared about doing the coolant change. I did change the coolant on the Magna ok. They do say you should do one thing every day which scares you
Re: V6 overheating
Posted: Wed Sep 07, 2011 2:57 pm
by missfixit70
Just be methodical about it, take your time & have someone help you at least the first time, checking levels etc (although it's easy enough to do it on your own), you'll be fine, it's not as difficult as people think.
Re: V6 overheating
Posted: Wed Sep 07, 2011 3:04 pm
by bongomike
Thanks is it just the case if emptying the coolant from the bottom of the rad is there any where else?
Re: V6 overheating
Posted: Wed Sep 07, 2011 3:15 pm
by missfixit70
I usually empty from one of the rear heater hoses & the lowest points on the large bore hoses in & out of the engine aswell, if you just drain from the rad, you'll leave a load of coolant around the rest of the system due to the way the hoses & pipes run. Have the rad cap, header cap & bleed hose bung out (only take the bleed bung out after removing header cap, it tends to spray all over when you forget
Then flush through everwhere with a hose till it runs clear everywhere, making sure not to get starter/alternator etc wet. If you're fitting a new stat, I'd run it up with no stat in for few minutes just to circulate everything & hopefully dislodge any crud lurking around, don't get it too warm unless doing a chemical flush or you'll have to bleed it & then allow it to cool a bit before flushing with clean water again.
Then fit the new stat, put in the neat coolant & top up with water & commence bleeding.
That's for a diesel, not done a V6, but it seems to be essentially the same cooling system set up.
Re: V6 overheating
Posted: Wed Sep 07, 2011 4:40 pm
by cheffy34
missfixit70 wrote:Bottom hose gets hot, same as the diesel I think.
Yep takes just aslong aswell me thinks.. yours and haydns youtube vid is the muts and gave me the confidence to bleed mine and flush it
TOP BANANA
Dar
Re: V6 overheating
Posted: Thu Sep 08, 2011 9:29 am
by Cloughy
haydn callow wrote:can you let me know the amp rating of the relay Wheelquick fitted to cause the i-alert to switch the fans....
The relay that's used to switch my rad fans from the iAlert is a:
Raylex Ellec 1A-12F
coil: 12VDC
cont. 40A 14VDC
this was fitted by the freelance auto electrician that does electrics for Wheelquick, they ring him when needed. PM me if you need his number.
HTH
Cloughy
Re: V6 overheating
Posted: Sat Sep 10, 2011 12:26 am
by The Great Pretender
Now we have head problems with the V6, are the 2lt engines showing similar symptoms too?
Could this be due to the mid engine configuration?
