which fuse
Re: which fuse
Hold on... lets clear something up. Do you have this stuff live from a leisure battery?? If so? you may have an inverter hidden somewhere?? Perhaps behind the rear panel, near the lighter socket..? Just a guess!
Re: which fuse
See my link to Alifriendee's thread earlier
Re: which fuse
Or it could just be you've got a leisure battery on the way out?
Re: which fuse
missfixit70 wrote:See my link to Alifriendee's thread earlier
Re: which fuse
No invasion of Poland jokes please....!missfixit70 wrote:You started it![]()
- peanutcrusher
- Tribal Elder
Re: which fuse
right what i think i'll try is to disconect the whole light fitting, does have a plug on it or will i need to cut the wiring?
the battery is brand new.
there are no invertors in the van so its not that.
it seems to flatton the battery in about a week with no use to the van.
Bongo now work later !!!
Re: which fuse
missfixit70 wrote:It's only usually the middle flourescent type light that can cause the issue, only takes a few minutes to remove it.
Grip the sides of the plastic lens at the switch end firmly, squeeze & pull down to remove it, then you'll see 3 screws holding the fitment in place, undo those, then you can access the electrical connector behind, undo that, job done
- peanutcrusher
- Tribal Elder
