Thanks for that Poohbear, I'll follow it upPoohbear wrote:I use 303 Aerospace Protectant http://compare.ebay.co.uk/like/15079589 ... pla&crdt=0mikeonb4c wrote:What might we use I wonder to prolong the life of the the rubber AFT gasket, given replacements may not be available.
You can also use it on all plastics to make them look like new and protect them from the effects of the weather
Protection for rubbers and boots
Re: Protection for rubbers and boots
Funny you should say that. I only noticed the split after the assembly had come back from the man down the road with the spring compressor (not suggesting it happened there, though). At least I was able to tape it before it went beck on the van. A lot more comfortable to work on in a well lit kitchen than up in the wheel arch!Driver+Passengers wrote:... I too have a cracked shock gaiter and will go ahead and repair it if I can, though I don't have a spring compressor so space might be tight...
I thought about the issue of the ball joint rubbers being stiffer after taping them but decided that it would approximate to the stiffness of the factory components whereas the replacement parts had 'rubber' more appropriate to party balloons.
Frank
They flew, I took up naturism
- Driver+Passengers
Mine is right up near the top.Diplomat wrote:A lot more comfortable to work on in a well lit kitchen than up in the wheel arch!
I guess what I was wondering is how stiff if too stiff, ie could a drop link rubber for example pull the rubber and spring clip off the body when at full deflection. Probably not though, just a thought.Diplomat wrote:I thought about the issue of the ball joint rubbers being stiffer after taping them but decided that it would approximate to the stiffness of the factory components whereas the replacement parts had 'rubber' more appropriate to party balloons.
Other products I've found while searching around a bit...
- Wurth Rubber Care
- ARMOR ALL Protectant
- Autoglym Vinyl and Rubber Care
