egr?
nth
Re: egr?
Post by nth » Tue Sep 17, 2013 8:51 pm
briwy wrote:I've blanked off both ends and taken the pipe off completely.
makes it so much easier to get at the glowplugs and bits on that side of the engine.
Its worth cleaning the manifold the manifold while you're at it, usually full of gunge.
Hi, where did you get the end stop thingys to enable you to remove the pipe completely when blanking the EGR.
95 2.5d 4WD AFT
Re: egr?
Post by Northern Bongolow » Tue Sep 17, 2013 10:17 pm
allans at plymouth. =D> =D>
meek.tv
Re: egr?
Post by meek.tv » Sun Sep 29, 2013 4:12 pm
I managed to install the blanking plate towards the rear today, when I went in to check I noticed that the one at the front was leaking horrible black gunk everywhere.
One of the bolts had started to work its way loose, when I removed the two front bolts it looks like it's picked up some extra metal from either the plate or I've killed the thread that they used to sit in.
Now they won't tighten down fully and when I rev it I can see more black gunk working it's way out. The rear plate is now fitted so I'm assuming that it's pressure is coming from the inlet manifold side? am I right in thinking that nothing should be coming through the Egr pipe now?
Any advice on what to do about the thread for the bolts?
Starting to regret messing with it now :-s
.......... cycling more.
Re: egr?
Post by Northern Bongolow » Sun Sep 29, 2013 5:38 pm
either re tap, or helicoil or ive fitted imperial bolts with a slightly coarser thread in the past, it works fine.
meek.tv
Re: egr?
Post by meek.tv » Sun Sep 29, 2013 5:56 pm
Thanks Northern Bongolow. I'll get the mechanics in work to have a look tomorrow, they have proper tools and everything :D
