Sorry guys busy times.  I appreciate the replies.
Bob wrote:If you decide to fix this on the road make sure you have plenty of tax and MOT. The latter is difficult to get if the job drags on.
Thanks for that Bob seems like pretty sound advice.
mikeonb4c wrote:winchman wrote:
In my experiance I have found if you can establish the fault then spend the money fixing it then you have a vehicle thats right.
If you trade it in you have another unknown.
I replaced the head on my car at 175000 miles cost £500, its now done over 200,000 and drives like new, of course I could have scrapped it and bought another £500 car but again its an unknown.
The OP needs to sit down and weigh up the money he has to invest in a vehicle and what best suits his needs, then decide how to spend it, you must remember if you spend say £8000 on another you will loose £1000 when you drive off the fore court.
I would fix it but thats me as I believe in keeping vehicles on the road and not throwing them away.
I'm inclined to agree, provided the Bongo otherwise has plenty of life in it ( i e no serious rust problem)
My thoughts exactly.  One of my key problems is knowing how much rust is too much rust.  I mean it does have some rust, but it's only done about 115k so running perfectly it ought to have a few years left and be worth a fair bit more than a grand.
Part of me is interested to try fixing it just for the sake of the skills I'll develop in the process.  I accept that may not always make a lot of sense financially, but how often am I gonna have a broken/possibly broken van outside my house to practice fixing up (obvious bongo break down jokes aside
ELZE I particularly like your point about reselling the parts, I hadn't thought about that.
NathM wrote:Are you sure the cooling system was fully cleaned? its not uncommon to leave a pocket of oil somewhere in the system. You have experienced a gasket failure so you know what the symptoms are, if your not getting any over heating or over pressuring then carry on driving it!! remove the sludge stuff and check again in a week and see if its reappeared or if it was left in the system from before
Nath
In all honestly Nath I've got no idea, but I guess I'll carry on driving it for now and get it up to Cramlington for a pressure test.  The problem with a straight comparison with the previous head failure, is that now we don't have a thermostat in, so it's staying pretty cold.  The warmest its got (according to Haydn's temp sensor) is 85 C and that was over the hills round Allendale.  To be honest, other than the gunge, which I cleaned out the other week I don't think we have any conclusive symptoms, although I'm always pretty uneasy with it all the same.
I dropped my usage right off to give me some space to think.  Now I should probably get back using it and try and diagnose as best I can.
Can anyone comment on whether other than when I'm bleeding the system I need to avoid being on a slope for the actual process of doing the head change?  Cos I can easily role it on to the flat to bleed it once it's been put together?
Thanks again for comments, sorry for the prolonged absence.
