I agree with Dandy. Thinking about it, if the radiator has the outlet on the neck, what other differences are there on it?
Should have looked more closely.
If it has all the other correct bits, then it should be ok to just blank it off, but better make sure.
Dandy, the pressure for blow off on the radiator cap was MUCH higher than the pressure blow off for the expansion tank, so surely this would have blown off first if it were pressure in the system.
Also, when the system was warm and running, Wayne removerd the header tank cap and there was pressure in there, but no more than normal, by the noise it made on removal. I know that listening is not an accurate indicator, but you know what I mean.
Also, the leak is a dribble, not under pressure, by the look of it.
Hope this helps
