Page 2 of 2
Re: coolant alarm fitting
Posted: Sat Feb 28, 2015 6:42 pm
by Bob
Glad we had a good one. 8)
Posted: Thu Mar 05, 2015 10:38 pm
by silage
being installed by dealer before we pick the Bongo up sometime this month. :)
Posted: Thu Mar 05, 2015 10:40 pm
by Bob
Well done. :D
Posted: Wed Apr 22, 2015 4:55 pm
by orangepeel
I'm fitting a coolant alarm and have a couple of questions. How do I get wires from inside the van (the dash) to the header tank for the radiator, is there a hole I can use or do I have to drill through?
Also, I was going to use the blanked off switches for the LED and test button, do they just pull out or is it more complicated than that? Thanks in advance.
Posted: Wed Apr 22, 2015 5:10 pm
by Gasy
Behind the glove box is a huge rubber grommet
Push a coat hanger through it tape your cables to it and pull it back jod done
Think the blanks have a Lig behind each side which needs squeezing in , might just pop out with a flat head driver and a bit of work
Posted: Thu Apr 23, 2015 10:10 am
by orangepeel
Great, sounds nice and easy. Thanks very much for the info.
Posted: Thu Apr 23, 2015 11:17 am
by cmm303
Also a grommet on RH side of bulkhead.
If having difficulty removing blanks in the instrument surround, this comes off dead easy (4 screws, 2 top, 2 bottom) giving full access to its switches and blanks.
Posted: Thu Apr 23, 2015 5:38 pm
cmm303 wrote:Also a grommet on RH side of bulkhead.
I used that one. I wanted to mount my warning light in the instrument cluster so it made sense to lead wires in on that side.
