ODBC/ ODBC2 interface socket on Bongo?
Rapidair65
Re: ODBC/ ODBC2 interface socket on Bongo?
Post by Rapidair65 » Tue Sep 08, 2015 12:34 pm
Just received yet another adaptor cable. A continuity test shows that only two pins in the diagnostic plug end feed the reader connector. These are FEN (missing on my plug) and a blank position on row 3. The +B power pin is not connected. That's why the reader will not work!
1998 green and silver V6 called 'Blossom'
2004 white 2 litre tin top called Buzz.
Post by Simon Jones » Tue Sep 08, 2015 1:26 pm
I've got an adapter lead at home somewhere. I'll try to buzz it out if I can find it.
sotal
Post by sotal » Tue Sep 08, 2015 4:44 pm
I had a quick look into OBD a month or so back, I didn't get chance to try it out but my research lead me to the following forum post...
http://forscan.org/forum/viewtopic.php?f=4&t=5
It doesn't mention the Bongo specifically but I think with a little tweaking that it could be used to make forscan work with the Bongo. I have all the bits somewhere to give it a go - so when I get chance I will have a play.
If anyone else beats me to it, then please post which pins you connected to which!
Rapidair65
Post by Rapidair65 » Tue Sep 08, 2015 6:36 pm
This looks promising. I will have a go at connecting the diagnostic plug tomorrow. Fingers crossed!!
the1andonly
Post by the1andonly » Tue Sep 08, 2015 8:11 pm
Simon another page of interest
http://mazda626.net/topic/39240-djdevon ... -i4-or-v6/
from above
Short history of OBD-I diagnostic systems:
OBD-I is a generic term given to any diagnostic system prior to 1996's introduction of OBD-II.
OBD-I is a blanket term and not an industry standard set of codes like we see with OBD-II. MECS-II is considered OBD-I, EEC-IV is also considered OBD-I. which is why we have to specify the difference in methods. Just because your car is OBD-I doesn't mean you'll use the same diagnostic system as an OBD-I BMW, Toyota, or Honda. Each manufacturer had their own OBD-I system. Mazda used MECS-II and Ford's EEC-IV system.
no longer online but have a pdf if you pm me
homepage.ntlworld.com/mx6-uk/malf/malfcode.htm
Rapidair65
Post by Rapidair65 » Wed Sep 09, 2015 11:36 am
It Works!!! Connected Autel MS309 as per the second diagram (Mazda 626 2000) and it reads the codes and scans perfectly. I have a duff lambda heater. Awesome!! Many thanks to all for the help and advice.
Post by g8dhe » Wed Sep 09, 2015 11:38 am
Ah good to hear!
Rapidair65
Post by Rapidair65 » Wed Sep 09, 2015 12:11 pm
Just tried the reader on our 1998 V6. Failed to link.The old girl obviously has steam powered diagnostics!
Post by g8dhe » Wed Sep 09, 2015 12:14 pm
Yup I've tried several to no avail on the R reg V6 of ours! I think the ECU's changed significantly after 2001 at some point to include the additional data channel.
Rapidair65
Post by Rapidair65 » Wed Sep 09, 2015 1:07 pm
Geoff,
I am going to try connecting additional wiring per the diagram for the 97-99 626 and see if that works on our V6. Fingers crossed!
Cancel that! Diagnostic plug on our V6 does not have pins at the two locations. We do have a FEN terminal so diagnostics may be possible using a shorting link per the fact sheet but I don't know which light will flash as we have no 'check engine' light.
Post by g8dhe » Wed Sep 09, 2015 4:46 pm
No on the older pre 2001 you have to add the lamp on the output pin, then they changed so that the flashing light also did the code, then I suspect they brought in the OBDII channel.
Mine works with an LED or bulb added for the output just fine.
