Oil leak from pipe connected to top of turbo?
Re: Oil leak from pipe connected to top of turbo?
Post by Northern Bongolow » Fri Aug 25, 2017 1:36 pm
sounds like a decent supplier, always makes you feel better when they quote working temps etc at you.
Dan_Will
Post by Dan_Will » Wed Sep 06, 2017 8:04 am
For the sake of completeness here is the new hose compared to old pipe and it fitted. For anyone in a similar position locally I got the hose made up by Gwent Hydraulic hoses in Newport. £20 + vat. Bargain if you ask me! :D
https://plus.google.com/110685261100668 ... XPnnYCUm91
Post by Northern Bongolow » Wed Sep 06, 2017 3:03 pm
keep yer eye on it, it will get a tad warm down the back of the turbo.
Grazedknuckles
Post by Grazedknuckles » Mon Jun 18, 2018 11:30 pm
Hi - I'm about to replace the same pipe (sourced a second hand one from Bongospares). Does anyone know the torque settings for the two bolts?
2003 AFT 2.5 heavy oil burner
Post by teenmal » Tue Jun 19, 2018 11:30 pm
Grazedknuckles wrote: Mon Jun 18, 2018 11:30 pm Hi - I'm about to replace the same pipe (sourced a second hand one from Bongospares). Does anyone know the torque settings for the two bolts?
11.8-17.8 Nm.
Grazedknuckles
Post by Grazedknuckles » Tue Jun 19, 2018 11:40 pm
teenmal wrote: Tue Jun 19, 2018 11:30 pm
11.8-17.8 Nm.
Thank you for the reply - that’s quite a range! Safe enough to aim for somewhere in the middle? Say 15 Nm?
victor3849
Post by victor3849 » Sat Sep 29, 2018 6:28 pm
Hi, I know this is an old thread - but related to this as I have the same age vehicle and engine, and I've broken the bolt holding the oil return pipe to the turbo body. Does anyone know where to source a replacement from? I have found the part code (14-285A) from lushprojects, but I cannot find that anywhere! Please help as I cannot drive the Bongo due to the oil leak :roll:
Post by Ian » Sat Sep 29, 2018 6:44 pm
It's Mazda part number B66014615 and available from Mazda UK for about £9.
