It would seem that split-charge relays have got a little more sofisticated since I last fitted one to a road vehicle. The one I last used was a simple high-current relay which connected the batteries together for charging purposes. Once the coil was energised, the contacts closed and the batteries were connected in parallel, so one would discharge into the other if the engine wasn't running to put some charge in. Obviously, with that set-up, if the coil was connected to the accessory (radio) terminal the relay would energise and connect the batteries together without the engine running.
I used the same set-up on my last boat, but the ignition switch on that had no accessory terminal as the auxilliaries were wired on a completely different circuit, directly from the leisure battery. It worked fine, and as far as I know is working still. The latest owner of that boat still belongs to the same club as me, and he hasn't said anything about it no longer working.
I haven't got a leisure battery on my Bongo yet, as so far I haven't needed one, but when I do I will take a closer look at the modern types of split-charge relay.
