Lack of Power
I agree the above Big E. 'Slipping' autobox sounds a weird concept on its own, but combined with refusal to rev sounds distinctly odd (not that I am a mechanic!). I seem to recall we have had a few tales on BF of garages saying this and that, doing this and that, charging for doing this and that, and it turns out to be something other which would have been simpler or cheaper to do in the first place.
Mike
Mike
Big E
Big E
- dandywarhol
Big E
In neutral - it revs all the way up. Put it in drive and the rpm goes up very slowly - getting to about 3500rpm before changing gear. It sounds as though the engine is trying to accelerate the car along, but it is not responding.
Went out with the garage mechanic - the engine is great in neutral - but shows little pulling power in drive. Its the only Bongo I have driven, so I can't compare it to other Bongo's.
When accelerating, you roughly expect when a gear change is going to occur, but the rpm just carries on increasing with no gear change. Is that normal?
- dandywarhol
Not normal Big E..............there's the possibility that the torque convertor is foobared........get a competant autobox specialist to check it out.
The torque convertor, as the name implies, multiplies the engine torque from idle (up to twice what the engine produces - that's why the Bongo's quick off it's mark)....if it isn't multiplying cos the internal stator has seized then the van will be really slow to pick up in gear, you'll use a lot more throttle to compensate, and therefore the changeup speed will be higher than normal.
Hope that all makes sense..........
