Help please - Aircon suddenly stopped working
kelv
Re: Help please - Aircon suddenly stopped working
Post by kelv » Sun Jun 07, 2009 7:34 pm
Bongolow Bill wrote:Pleased to see that that Bongo Entrepreneurs go boldly! I have used Air Con top-up kits on other vehicles succesfully......but not sure where to make the connection to the A/C system on my Bongo (1999 'Facelift' diesel SGL5 Auto Freetop with camper conversion....dual A/C with Climate Control). Kit advises using the 'Low Pressure' service connection....where is this located on my Bongo?......I have spotted a service connection point in front of the radiator which has HP on the cap.....if that is in fact the 'High Pressure' is there another 'Low pressure' point somewhere else? Many thanks (in anticipation of a 'cool' Summer....maybe!)
No, the air pipe with H on the cap is the high pressure pipe.
The low pressure pipe has an L on it and is situated behind the radiator about a foot down from the top of the engine bay, about a foot back from the front of the engine bay.
If you look at the big fuse box that sist on top, under the bonnet, it is under there, about a foot down.
No need to remove anything to get to it.
Bongolow Bill
Post by Bongolow Bill » Mon Jun 08, 2009 10:29 am
Many thanks....I'll give it a 'squirt' this afternoon to top up the system....you never know we might yet have that blazing hot Summer that the forecasters keep threatening us with! Sorted!
Seamus
Post by Seamus » Mon Jun 08, 2009 6:30 pm
I have a slightly different air con problem.
When I switch the climate control to auto the fans come on fine, the a/c pump works and plenty of cold air is blown out but after only two minutes the fans just stop but all the bars are still lit up on the display to indicate that the fans should be on. Any ideas or am I looking at a replacement climate control unit?
kelv
Post by kelv » Mon Jun 08, 2009 6:39 pm
Seamus wrote:I have a slightly different air con problem.
I do not know for sure, but I guess that the climate control unit activities, and the resultant auto fan settings are controlled from data supplied via the interior temperature sensor unit.
I would check that this is not obstructed or blocked in any way before examining the climate control unit itself.
Maybe the sensor needs a clean, or a new sensor, which is probably cheaper than a new unit.
Try that first if you agree with the logic.
Does it work for longer on the manual setting ?
Seamus
Post by Seamus » Mon Jun 08, 2009 6:49 pm
No, the fans cut out on manual setting too. I don't think it could be the sensor because all the fan indicator bars are illuminated indicating that the control system "believes" that the fans are on.
kelv
Post by kelv » Mon Jun 08, 2009 7:34 pm
No idea then.
Best of luck.
If you cure it, post the explanation :D
Post by g8dhe » Mon Jun 08, 2009 8:11 pm
It sounds like you have the electronic version. The control circuit has a relay that bypasses a transistor which is used to control the speed, it could be that whilst the relay is operating (for max power) the fans run, but that when it releases and passes control to the transistor either the transistor has blown or its control circuit isn't working, see the diagram below;
See G3-04 Transistor and G3-05 Relay (Max/Hi).
The locations are in the diagram below;
