Cooling system
- haydn callow
- The Great Pretender
- haydn callow
Nope, you got it right.bigdaddycain wrote:Can i just clarify? Did i read that correctly? You removed the stat,lost 5 litres of coolant as a result,yet the header/expansion tank was still at max? Forgive me if i got it wrong,that's how i read it...The Great Pretender wrote:I had a container under the Bongo when I removed it. 5ltr was lost but the tank was still up to level.
- dandywarhol
Yep - 16 postsThe Great Pretender wrote:was I, and I was told drinking red wine improved the memory, cant remember who told me.
Cant tell you what way it was fitted as I was working above it when it fell out.![]()
Yes it is your eyes. Didnt Mom tell you it would send you blind?![]()
Aint my floor it is my workshop work surfacewhere do you eat your lunch.
Getting back, I had a container under the Bongo when I removed it. 5ltr was lost but the tank was still up to level.
Find it difficult to believe that the cap vaccum is keeping the coolant in - that's a sizable hole where the stat livesThe Great Pretender wrote:Nope, you got it right.bigdaddycain wrote:Can i just clarify? Did i read that correctly? You removed the stat,lost 5 litres of coolant as a result,yet the header/expansion tank was still at max? Forgive me if i got it wrong,that's how i read it...The Great Pretender wrote:I had a container under the Bongo when I removed it. 5ltr was lost but the tank was still up to level.
- haydn callow
Seen this before but it is interesting reading and could be relevant.
However I still belive the cooling system on a Bongo, is good if well maintained.
http://www.mgfmavhh.ukf.net/
If they aren't being used, there is no airflow and thus little if any cooling effect from them.francophile1947 wrote:Can't shoot it down cos' I don't know but, if the heaters are permanently "on", with the heat in the van being regulated by flaps altering the airflow, why should it matter when the heaters aren't needed?scanner wrote: Bongos used in cold conditions may rarely (especially if used for lots of short trips) use their radiators, when they suddenly change to running in conditions where the heaters aren't needed, the radiator can't cope with the demand put on it as it's partially or wholly silted up.
Just a theory shoot it down if you like.
- haydn callow
Was that with the engine running, did it increase with engine speed?haydn callow wrote:TGP..I will look into this again but I did measure at around 4psi when up to 90 DegreesC.. I will try and work out a way of being more accurate.
The link I gave above is interesting reading.
The last paragraph gives me a nice warm feeling.
Let's put it this way Mel, if i looked at a schematic of the bongo's cooling system for long enough, i'd be inclined to put my hands over my ears,and start singing la la very loudly before my simple noggin overheated!The Great Pretender wrote:Am I on another planet bdc? need normalbigdaddycain wrote:I think this is beyond me to be honest...but i'll follow the thread with much interest,hopefully learning something along the way...people understanding this to, how can I help?
I won't pretend to understand the complete ins & outs of the cooling system, i can follow some of it, to a point...
I've seen simpler cooling systems on 300,000 tonne supertankers with engine rooms the size of cathedralsbigdaddycain wrote:Let's put it this way Mel, if i looked at a schematic of the bongo's cooling system for long enough, i'd be inclined to put my hands over my ears,and start singing la la very loudly before my simple noggin overheated!The Great Pretender wrote:Am I on another planet bdc? need normalbigdaddycain wrote:I think this is beyond me to be honest...but i'll follow the thread with much interest,hopefully learning something along the way...people understanding this to, how can I help?
