help-need a Fan resistor quickly again
Re: help-need a Fan resistor quickly again
Post by missfixit70 » Mon Nov 03, 2008 8:35 pm
No you're ok Anna, we'll leave you to it - you're a techie now :lol:
Sounds like yours could be on its way Brora, as Anna says, time to check the fan to see why, before it gets worse I reckon :roll:
not so old
Post by not so old » Mon Nov 03, 2008 8:44 pm
:D :D :D Sooooo excited-'I'm a Techni' =D> =D> =D> =D> Love it :lol: :lol: :lol:
missfixit70 wrote:No you're ok Anna, we'll leave you to it - you're a techie now :lol:
Post by Bob » Mon Nov 03, 2008 9:06 pm
Congratulations Anna =D> =D> =D>
not so old
Post by not so old » Mon Nov 03, 2008 9:25 pm
Thanks bob,
:? I think I knew what I was talking about at last- Techni Stuff Wow!!! There's no stopping me now, not even the restricters round my ankles :lol: :lol: :lol: :lol:
Cheers Anna
Bob wrote:Congratulations Anna =D> =D> =D>
Post by mikeonb4c » Mon Nov 03, 2008 10:50 pm
Way to go Anna =D> =D> =D>
brorabongo
Post by brorabongo » Tue Nov 04, 2008 12:31 am
not so old wrote:Hi,Brorabongo,
Hubby says that ours started like that- 1st 1 didn't work 2nd didn't work then 3rd didn't work. It probably is the resistor, but it is what is causing the resistor to blow, that needs checking- ie: Fan sticking in water or muck, bearing etc.
Hope I got it right, I'm just learning about techni things- Guys will be along soon.
Cheers Anna
Cheers Girls. :D
Looks like I'll be whipping it out then........ that is the resistor and fan of course. :roll: :lol:
Both where replaced by myself with second hand units straight after getting the Bongo, (two years this coming Feburary) and after seeing plenty of posts about it since, and thanks to the pics from DBO in this thread, I feel that it's worth a shot at repairing them this time, instead of replacing. :wink:
Now, where did I put that soldering iron. :-k
ボンゴの激怒 pictures
Post by mikeonb4c » Tue Nov 04, 2008 12:34 am
Go for it Brora :lol:
brorabongo
Post by brorabongo » Tue Nov 04, 2008 12:44 am
mikeonb4c wrote:Go for it Brora :lol:
Too late to go for it tonight!! :lol:
I know its an easy job to get to the offending parts, *drawing air in through my teeth sharply*........... but I think it may take me a whole afternoon to fix. :wink: :wink: (which will equal more "Brownie points" for me.) :lol:
ボンゴの激怒 pictures
brorabongo
Post by brorabongo » Tue Nov 18, 2008 3:59 pm
Job done. \:D/ .....at last!!!!
I wish I had this info when I first got the bongo, and parted with money for a replacement resistor. :cry: Whats even worse, I threw the old one away!!! #-o
The jobs so easy. ( even easier than replacing Starter contacts!! :lol: ) The only specialist tool required is a soldering iron, and they are not expensive.... http://www.maplin.co.uk/Module.aspx?Mod ... 1QodK1UNYA
Oh and a wee bit of solder helps. I used a small terminal /watchmakers screwdriver(flat blade) to push the tags together for releasing, and again to push apart once done. The metal tags are soft so it's easy enough.
Just one leg of the resistor had come away...
Thanks again for the photos DBO. :wink:
ボンゴの激怒 pictures
daveblueozzie
Post by daveblueozzie » Tue Nov 18, 2008 5:49 pm
No probs, :D but ive only passed info on that i received from this wonderful forum.
Lost without my Bongo.
bongomaan
Post by bongomaan » Tue Nov 18, 2008 10:40 pm
I am still unsure,can you resolder a digital climate resister ?,any ideas.... ps i also bought one not long after buying bongo...
